Thanks Vaughan I like the stand too, every time I catch it out of the corner of my eye I just have to look at it again
Well I spent 3 hours watching the last couple of episodes of Homeland (bloody marvellous by the way!) and that was enough to give the grey paint a good chance to dry out, so finished masking it up and just sprayed the light blue again. I'm not sure its going to be perfect, but in the grand scheme of things I hope it won't be all that noticeable. I might need to do some touching up when the masking comes off but that will now have to wait until all the paint is on. Leaving the light blue to dry now until tomorrow evening and its now time for bed...
Wow that looks amazing. When I used to work at Kemble they used to refurbe Hunters there used to go and chat ever now and again missed out on a test flight.
I don't know if there still there new the air craft painter there but the planes were mostly black but that was over 15 years ago.
This morning I got up a bit earlier and managed to mask and spray the roundel blue stripe and leave it to dry while I went to work. Then this afternoon, left work a bit earlier than normal and have been able to mask the roundel blue out and then spray what I think will be the first coat of dark blue...
I think I'm going to need another coat once this one has dried a bit so I'm off t'pub for a couple of hours this evening and since I'm driving I won't be drinking much so when I get back I should be able to give it the second coat before bedtime.
And then tomorrow will be the great unmasking, which will let me give it a good couple of coats of Klear tomorrow and Saturday morning, then by Saturday evening I can start on the decals. There won't be much in th eway of weathering to do on this as its kept pretty pristine and shiny - when the paint job was done they made an effort to fill in the panel lines with putty and sand it smooth as you can see here:
So I won't be making great efforts to highlight the panels or dirty it up like I would normally do on a plane. This means I can conceivably finish before my Monday deadline!!! Wow!!
The photo makes it look much better than it actually is... the demarcation line between dark red and grey is very blotchy and there has been some paint creep
Here is a larger version
I think I'll be doing some touching up this evening, hopefully it won't take too long and I can progress to putting some Klear on as well... the clock is ticking...
I have a deadline because I'm going on holiday next tuesday and I'm building this as part of a Single Type Group Build on another board and the deadline for that is 20th May which is during my holiday... The Aliens Dropship took so long it left me behind schedule for this one...
Sadly on closer inspection the demarcation line between dark red and grey was very ragged and has required a bit of extensive touching up with a hairy stick which brings its own problems of getting the paint colour to match since this is quite a complex colour mix and gradient! Looking at it again I think I will need to do some remasking and spraying even after the brush touch up just to blend in the brush edges, however this is going to take time and so I've had to sacrifice my original build schedule and slow down, which means there is no chance of completing the build before I go on holiday next Tuesday. I was getting too stressed with my previous timescale and thats no good - this is supposed to be a fun hobby and this evening all the fun had vanished. So I'm going to slow down and do a proper job rather than trying to rush it.
Good news is that the pilot arrived from PJ Productions today
So that means the cockpit can proceed as well. I've got a bit of a busy weekend ahead with getting ready for holidays, so not sure if much more progress will be made, but if there is, I'll be sure to update this thread
