Airfix 1/48 Gannet
  • yak face
    • Jun 2009
    • 13836
    • Tony
    #76
    Crozzled , yes I understood perfectly andy , its how I like my bacon , must be just a sheffield thing. Youre right about not giving it a panel line wash , it would just get in all the nooks and crannies and be a bugger to get out again . Perhaps another coat of satin , acrylic might fill in some of the wrinkles ? If it works I might try it on my face !
    • The Smythe Meister
      • Jan 2019
      • 6248
      #77
      What about a Flory wash?...SO easy to use,gives great effects,and... If you don't like the outcome... Just wipe it off again :thumb2:
        Might polishing work?
        • Andy T
          • Apr 2021
          • 3239
          #79
          Thanks for the suggestions chaps but I think I'm on the way to sorting it.
          A light nib (sanding) and a few coats of Aquagloss have buried the worst of the texture:
          It's only in the odd place where I sprayed too wet and the lacquer has eaten into the acrylic, so hopefully by the time it's had a clay wash (UMP's version of a flory wash) and a satin varnish, it should be acceptable from a normal viewing distance (like the moon) :tears-of-joy:
          I've got the props & spinners finished too. I may add a light bit of chipping to the blades but overall I'm not doing too much in the way of weathering:
          • Waspie
            • Mar 2023
            • 3488
            • Doug
            • Fraggle Rock
            #80
            [ATTACH=CONFIG]n1218509[/ATTACH]
            [ATTACH=CONFIG]n1218510[/ATTACH]
            Wowser's Andy, loving that prop. Superb finish on the spinner and props!!
            • JR
              • May 2015
              • 18273
              #81
              Looks like you've sorted it Andy, good for you.
              • Andy T
                • Apr 2021
                • 3239
                #82
                It's ironic that I only glossed as I wasn't sure the vallejo would stand up well to decal solutions. Might have made less work if I'd not bothered :tears-of-joy:
                • Flip
                  • Jul 2022
                  • 257
                  • John
                  • Speyside
                  #83
                  Good recovery, Andy.
                  If that had been mine, I would have thought I had permanently ruined it; so it's good to see that recovery is possible.
                  • Scratchbuilder
                    • Jul 2022
                    • 2689
                    #84
                    Andy, I was about to say that a light rub down with some of the fine (1000+) sanding pads should reduce this, and after watching someone on YT with almost the same problem a couple of coats of varnish sorted out his problem, plus it reduced the gloss of the decals. But you have beaten me to it.
                    • Andy T
                      • Apr 2021
                      • 3239
                      #85
                      Thank you both. It's still visible to the naked eye but the camera hides it well :smiling5:
                      Had a good few hours on this today and made decent progress. There are still a few vulnerable bits to add but I'm getting closer to the finish line.
                      • Mark1
                        • Apr 2021
                        • 4156
                        #86
                        Coming together nicely mate, been trying to resist but finally gave in and just ordered this one for the stash.
                          • 15679
                          Glad it's sorted 'cause the build is great and it would have bugged you :smiling2:
                          • Waspie
                            • Mar 2023
                            • 3488
                            • Doug
                            • Fraggle Rock
                            #88
                            Looking very good Andy.
                            • Andy T
                              • Apr 2021
                              • 3239
                              #89
                              It has been a really enjoyable build. Just my kind of thing, with a great fit and thoughtful engineering.
                              Absolutely! Back to bulletproof lacquers for this kind of thing I think.
                              Cheers Doug
                              Flaps and under wing ordinance were fitted this morning. Both were such a tight dry fit that I haven't even bothered to glue the flaps. I didn't want to risk breaking their delicate brackets by removing them.
                              • Andy T
                                • Apr 2021
                                • 3239
                                #90
                                And finished.
                                I'll post some more pictures up later but here she is:
