Edward FW190A8 1\48
    Edward FW190A8 1\48
    Started this in the wrong place, Bloody hard has taken me all weekend and lots of teddy throwing's out of pram, PE so small and fiddley some bits size of a pin head..
    please be kind i've got hands like shovels.
    Martin
    looks ruddy well ok to me,i`m impressed
    mobear
      great cockpit
      Roman
      • AlanG
        • 6296
        Like this Martin
          • 18272
          If you can make that with a pair of shovels. I wonder what you could do with dainty youthful fingers!!!
          That's a very nice office and I do like the look of that harness.
            Thank you all for the kind words, was very nervous,Flounder you have the same kit? have a look at the PE nice and pre painted but really small, thank argos for the magnifying glass and light that most of you own.
            Roman how do you go so fast? the 1/48 pieces are so small and you virtually complete one in a few days?? your praise is most welcome..
            Regards and Respect to you all.
            Means a lot .
            Martin
            • AlanG
              • 6296
              Yes Martin i have the same kit. I've already been introduced to Eduard PE and know how small the little blighters can be lol
                I have to admit I find PE very difficult as well and end up with more bits stuck to the end of my tweezers than on the model!!
                You've done a great job there and the harness looks superb. Don't worry you'll gain in confidence as you get more models under your belt.
                • InFlames
                  • Feb 2012
                  • 466
                  That's some very nice start on the Wรผrger!
                    Righto here we go , Cockpit fitted, Airframe glued, Forget who gave me advice to stick upper wings to fuselage first Thank you that worked a treat. now dry fitted lower wing section and the reason the advise was given, bit of a git to fit,( had a tax refund arrive last week so bought myself a dremel 300 with ext shaft)so shall be using my new toy to get it to fit.
                    Again thanks for all the advice and kind words.
                    Martin
                      Havn't had much time with this as i'd like, would any of you please give me some idea's for colours for wiring hydro lines and other stuff, as i wont to have every thing open top and side cowls you'll see in the photoes RLM02 is so boring.
                      Thanks in anticipation
                      Martin
                      • stona
                        • Jul 2008
                        • 9889
                        As a generalisation hydraulic lines were brown,black or aluminium. Pneumatic hoses black. Electric wiring yellow.
                        Here's a view into the port weapon bay. The weapon has been removed.
                        The cannon would face to the left the ammunition fed from boxes within the fuselage,at the top of the picture (infront of the electrical gubbins). Casings and links were ejected via the chute at the bottom left of the picture. The EDSK-1 electrical distributer box would probably be black,the wiring yellow.
                        Here's a view into the wheel well.
                        The top of the main gear leg is just visible at top right. The radius arm has the wiring running down it and the black circular device in the spar is the electrically driven actuator,a rotating drive,for raising and lowering the gear.
                        Here's another view.
                        The leather clad arm to the right of the rotating drive,attached opposite the radius strut,is a sealed air jack. It was pressurised to 1400psi and spring loaded. It served,along with gravity,to lower and hold down the gear in the event of an electrical failiure.
                        There really isn't a lot inside the wheel well. You can muck it up a bit with a wash,make it look like a bit of oil or other fluids have got in there but that's about it.
                          Looking great Martin and Steve comes through with the goods yet again,what a great forum! Looking forward to seeing more of this build!
                            Wow them photo's are amazing, Thank you very much got just the right thing for the wireing, Gonna be tight in 1\48 but i'm gonna try.
                            Thank you for taking the time to post them meens a lot.
                            Cheers Trey more photoes by end of day,Hopefully.
                            Thanks again for helping
                            Martin
                              • 22788
                              Looking very good so far Martin and will look a lot better when you add the colour to the wires and pipes
