Airfix 1/72 bf109e-4 Franz von Werra
  • yak face
    • Jun 2009
    • 13829
    • Tony
    #31
    Bit more done on the aircraft and figures. Ive cut out the access panel on the right side of the engine cowling as the photo shows this to be open . I added the panel from plastic card and luckily the basic engine shape airfix moulded can be seen through the cut out . The figures from the set have been altered using the different arms so the two home guard chaps look like theyre just standing about , guarding the aircraft. Click image for larger version
ID:	1222366Click image for larger version
ID:	1222367Click image for larger version
    • spanner570
      • 15384
      #32
      Nice progress Tony.
      I'm really sorry to have shot you down during the Battle of Britain, but it was our sky!
      At least you were able to see a bit of my country, travel to Canada, then the USA all for free.......
      "There are no enemies in the Brotherhood of the Skies."
      'Stapme' Stapleton
        Watching and learning. Very useful to know how to make a nice little diorama. Build looks good - would you say the panel lines are a little heavy on Airfix kit? Regardless I am looking forward to build completion
        • HAWKERHUNTER
          • Feb 2012
          • 1562
          • Steve
          • Halifax, West Yorks.
          #34
          Looking good Tony.
          • Lee Drennen
            • 7711
            #35
            Very nice Tony
            • yak face
              • Jun 2009
              • 13829
              • Tony
              #36
              Finally started on the base today . Got myself a tub of tile adhesive ( about £2 , Home Bargains ) which I spread onto the base , not too thickly . Once it looked like a Ryvita covered in philadelphia it was time to think about how i was going to get the ploughed field effect. A bit of cardboard was sourced and the outer layer stripped off to reveal the corrugated middle , which once dragged over the adhesive gave me the furrows I needed . A sprinkle with sand and a few tiny stones and it looked about right. Click image for larger version
ID:	1222685Click image for larger version
ID:	1222686Click image for larger version
ID:	1222687Click image for larger version
ID:	1222688Click image for larger version
ID:	1222689Click image for larger version
ID:	1222690Click image for larger version
ID:	1222691Click image for larger version
              The model was protected with some cling film and then dragged / scraped over the surface to represent the skid mark caused by the belly landing . The two underwing radiators left a nice pair of tracks . Its now drying and tomorrow I can look at getting some paint on it and adding a few bits of vegetation Click image for larger version
ID:	1222693Click image for larger version
                Cool idea to use some corrugated card
                • yak face
                  • Jun 2009
                  • 13829
                  • Tony
                  #38
                  Got the decals on today , next for the airframe is a coat of matt and then plenty of muckying up. Click image for larger version
                  Meanwhile the base has dried , but a lot of the sand and stones are still loose . This was sorted by the liberal application of hairspray . This has stuck everything in place ( and made it smell nice!) so hopefully when I spray it brown the airbrush wont blow it all off . Click image for larger version
                  Ive also made a start on the figures , just a bit of highlighting and painting the various straps and kit to be done Click image for larger version
                  • Andy T
                    • Apr 2021
                    • 3239
                    #39
                    Great idea for the furrows!
                    • yak face
                      • Jun 2009
                      • 13829
                      • Tony
                      #40
                      Base has had its first couple of coats of brown , the sand all stayed put! It’ll be getting more coats and a bit of variation then I can look at getting a bit of vegetation on. Ive finished the two figures , not brilliant but at this scale im happy .Click image for larger version
ID:	1222787Click image for larger version
                        • 15669
                        This is coming on really well Tony. The 109 looks excellent with the fine paint job and now decalled up. Those figures look rather nice - certainly better than I thought Zvezda snap together ones would be. The ploughed field is brilliant. Clever idea that's worked very well.
                        • yak face
                          • Jun 2009
                          • 13829
                          • Tony
                          #42
                          Cheers jim , yes the figures arent too bad considering , theyre not up to the standard of the 3D printed ones I got recently - those are superbly detailed - even makes my painting look good!
                            • 22770
                            #43
                            Just caught up Tony, some cracking work going on, looking very good indeed.
                            • HAWKERHUNTER
                              • Feb 2012
                              • 1562
                              • Steve
                              #44
                              Loving this one Tony. Really good work.
                                I love this build - I did say that I thought panel lines a bit deep but it is such a cracking good paint result - some pin wash will probably accentuate those panels in a great way. Very impressive!
