Sopwith camel 1/28 by me Ole
    That's certainly a wild paint scheme! Well done Ole for giving it a go, it must have been tough to do it so well!
    Patrick
      finger marks are the downfall of this as there is so much white,and with the colours so defined the edges never seem to be perfect but i`m happy with the overall outcome
      mobear
        • 22770
        #78
        Great work on the colour scheme Ole
        • aaron
          • Oct 2011
          • 2019
          #79
          Love that paintjob Ole. It must be choice to work in such a big scale.
            Ole killer looking paint job! Really nice to see some wild off the beaten path schemes keep up the great work!
              Its like the carnival has come to town, you could add a half naked girl on that doing a bit of "wing walking"
              Looks dead smart mate, i can imagine the time you nearly swore getting that right
              Waiting for the assembled piccies now !!!
                thnx guys,well the struts are all wrong and the wheel base has to have a lot of care alterations to make it level,but hey ho.The wife is glad the blue sky is outside so she can sit in it, out of the way of the flack from me lol
                mobear
                  okay i did a dry fit of the wings today and arghhhhh its all warped but looks gorgeous so here you go [ATTACH]42689.vB[/ATTACH][ATTACH]42690.vB[/ATTACH][ATTACH]42691.vB[/ATTACH][ATTACH]42692.vB[/ATTACH] now any suggestions on how i maybe able to twist the top wings without breaking the struts or another method to try will be helpful,just don`t want to hurt it now
                  mobear
                  [ATTACH]45990.IPB[/ATTACH]
                  [ATTACH]45991.IPB[/ATTACH]
                  [ATTACH]45992.IPB[/ATTACH]
                  [ATTACH]45993.IPB[/ATTACH]
                    Build a cube, bigger than the plane with dowel or bamboo sticks, attach this to a solid base.
                    Strap the plane down onto the solid base (drilling two holes in the base and using a cable tie will work fine) and then use elastic bands to hook aver the wings and pull them at what ever strength it takes to get the wings right. (shortening the bands will give more pull, longer bands will provide less etc) you can tie/attach/hook the elastic to any place on the cube struts so you have full control over the situation.
                    Check quite a few times throughout the drying period and adjust to suit by either twisting the elastic to tighten or stetching it a little to take away the elasticity of the rubber.
                      thnx colin i will give that a try
                      mobear
                      • HAWKERHUNTER
                        • Feb 2012
                        • 1590
                        • Steve
                        • Halifax, West Yorks.
                        #86
                        Hi Ole. I wouldnt worry too much about the wing problem. Its often frustrating because as you build a model we notice faults that quite frankly no one else viewing the model for the first time would notice. I have often returned to a model many weeks after completion and noticed that all the little things that were a problem during the build were just not noticeable later. If you are that worried about the wings the only I can think is that once you have set the wing level just apply a bit of gentle heat from a hairdryer to coax the plastic into the new shape but be careful. The plane looks great mate.
                          thnx steve the problem is the end struts they dont want to go in their desired slots,its roughly 6mm one side ,and 5mm the other side,so i`m between a rock and hardplace on how to rectify it,the jig i will try dry fit first,also using the waxed button thread to do the holding with springs that are home made,so that the pressure is not to great,then if it fails,heat it might be.
                          mobear
                            I bet there are not many of these kits end up in those colours! What a brilliant and individual looking model.
                              top wing is now installed dyhedral fixed and thnx andy jig worked,but used super glue to set it quick,then prayed alot.then hay presto its on and i`m happppyyyyyyy:smile1:
                              mobear
                                Coming along nicely Ole
