Eduard 1/48 Scale Bf 109G-10
    Originally posted by Easyrider5258
    You don't Have to bother with the PE most of which won't be seen when assembled, in the cockpit just assemble seat, joystick, instrument panels or whatever you feel you can do, the 109 is a small aircraft anyway and will be easier to just get the kit together without all the unseen pe detail
    You mean get the Weekend edition then? :smiling5:
      Eduard models come in 2 flavours - the ' Profipack ' like yours, with PE, masks & usually 3 or 4 marking choices - the alternative is the ' Weekend ' boxing this doesn't have PE or masks & you only have maybe 2 markings. The Weekend boxings are cheaper! I wonder at times whether the Profipack is worth the extra cash - I very rarely use more than 2 or 3 bits from the PE fret & you only have one model - so the unused decals go into the spares box, never to see the light of day again! With PE you really do have to ask yourself - ' Will this improve the model?' With Eduard the PE is an alternative to plastic, so you don't actually have to use it!
        I have often mulled over this myself and so have a mixed stash. What makes Profi good are the belts, cockpit placards (no bending) and masks.
        If you are modelling a 72 kit then I don’t see the benefit and less still if the canopy is closed (see my current build if you wish)
        you can mask yourself if you have some experience but it’s a critical part of the kit (ditto).
        you can make your own belts (ditto)
        if you are building a 48 with an open canopy then the profi or no profi is a little more subjective
        buying either masks or belts makes it justifiable to go profi.
        We spoke about this the other day - some of those PE pieces are taking the PE! lol
          Been thinking about this overnight and I've definitely decided to 'park' it and return when I have 2-3 more kits under my belt.
            Originally posted by SteveT
            I could easily have this wrong but I think it was supposed to be painted, here's that bit of the instructions: PE26 is the part and unless I'm mistaken, it does say to paint it black grey?
            [ATTACH]505191[/ATTACH]
            But frankly it's a moot point because I've decided to just slide this back for the time being and work on something else, I don't feel up to tackling PE now I've seen it up and close. So I will very carefully file this and return after one or two other kits.
            If you get an AZ joypack you get 3 decent kits for about £20 or less. You will need some decals though
              Good plan. Build a few more kits that you can actually finish with the skills you have, thereby developing those skills more while also avoiding getting burned out on kits were you now feel like you’re fighting them all the way.
