Tamiya 1/48th Scale Spitfire Mk Vb
    Morning Steve,
    Have read through your build, what a mess!!! is how you would describe it. We on the other hand can see a productive modeller, working his way through several problems and all at the same time. Overcoming those problems and completing the model is your glory and pleasure. OK, so you made a few beginners mistakes - we all do it even if we have years of experience. So you get this one finished, and out of your 'stash' you pick the next most 'difficult' and work your way through each one, and through that you will be gaining more experience.
    So to your model.
    You worried about those raised lines on the wing tops, they are for the Mk.5 and are wing strengtheners and really who is going to know.
    Masking. Ok so you let a little paint through, here is a tip. When you mask up your cockpit or any opening and use paper/tissue, then go around the join with some masking fluid which will peel off after you have finished painting.
    Masking 2. If I remember correctly Tamiya included a full size camoflague print you could cut the sections out and using blutac to hold them down, then gently spray around the edges from the print to the model so that you do not lift the print and spray underneath and finish up with a slight soft edge to the camoflague.
    Overall impressions. For a second model, you sir are putting a lot of us to shame if we are honest and remember our first models - my first was a 1/72 Airfix DH.88 and it took a whole tube of Airfix glue to glue it and myself to the sofa, then the dining table - points earned - a clip around the ear..... So you are not doing as bad as you imagine you are.
    • Andy T
      • Apr 2021
      • 3239
      #47
      Steve, I combined this method with the same masking putty you have on my swordfish build.
      I have some pictures but I'll only post them if you are happy for me to, but basically I cut out the shapes, laid them on the wings and lightly pencilled around them, then applied the masking putty using these lines as a guide.
      As has been said, you don't have to be accurate with your patterns, your model, your choice, but if you wanted to in the future it's one way of doing it.
        Thanks everyone. I feel quite guilty now complaining, re-reading my comments it's like I'm seeking pity or validation and that's not the case.
        I'll be honest I get depressed quite easily and last night I was even thinking of tossing it in and wondering how to sell all my stash ..but after a nights sleep, I woke up
        with some determination to see this through.
        So this morning I've been masking the fueslage sides, nose and leading edges of the wings as I wanted to spray the underside without overspray ruining the camo.
        I've done it now and am waiting for it to dry before peeling it off. Fingers crossed!! I've done it grey though as I don't have the correct colour listed.
        Images to come.
          Morning Steve,
          So to your model.
          Good grief Haha!!! I just rummaged through the box and found that right at the bottom! ohhh that's a facepalm, that's my own fault for missing it or not taking note when I opened the box. had to laugh though!
          but.. I'm not planning on redoing the camo (unless I've bodged it with my underside spraying which I'll see in about 30 mins.)
            That would be interesting to see.
              Okay, I just gritted my teeth and removed the masking. So here she is with the underside painted.
              is she perfect? No!
              am I happy with the result? Yes!
              also sorry for the bad images, my camera sucks.
ID:	1221749Click image for larger version
ID:	1221750Click image for larger version
                You know part of me says "That's okay" crack on and finish it. and part of me says "That camo is just wrong, you need to just repaint the wings and fuselage with the correct camo"
                  Nothing wrong with that model, if you ask me. If it were mine, I would just finish it as it is now without bothering to correct it, and think about doing another in future that does have the camouflage as per the original. That way, you get the satisfaction of a completed model and of something to look forward to improving on
                    Originally posted by Jakko
                    Nothing wrong with that model, if you ask me. If it were mine, I would just finish it as it is now without bothering to correct it, and think about doing another in future that does have the camouflage as per the original. That way, you get the satisfaction of a completed model and of something to look forward to improving on :smiling3:
                    You know you read my mind! That is my exact plan as of a couple of hours ago. Because I have another Spitfire in the post.
                    but it'll be a while until I build that as it's 1/24th! So tonight I've been working on the canopy which was interesting and quite tricky to mask but we'll see what it looks like when painted!
                      is she perfect? No!
                      [ATTACH=CONFIG]n1221749[/ATTACH][ATTACH=CONFIG]n1221750[/ATTACH][ATTACH=CONFIG]n1221751[/ATTACH]
                      Don't worry about the bad focus, I try that with all my work - fools the older members into thinking its their eyes.....
                      Underside looks fine, wait untill I start my aircraft building after the June Nationals, then you are going to see some mistakes...
                        Little update. Yesterday I spent most of my time attempting to mask the canopy. Ideally I wanted to use liquid mask but I have a heap of trouble
                        applying that to curved surfaces, so I used masking tape and a lot of time fiddling about. The result is so-so
                        Meaning it looks great from a distance but not good up close (but not totally a bad effort for a first go imo)
                        • Andy the Sheep
                          • Apr 2019
                          • 1864
                          • Andrea
                          • North Eastern Italy
                          #57
                          If some paint spilled underneath the masking tape on the canopy, try to remove it by gently scraping it with the tip of a wooden toothpick; it often works.
                          • Waspie
                            • Mar 2023
                            • 3488
                            #58
                            Better than my first attempt at canopy’s Steve!! Mine looked about a foot wide. See my 1/72 sea king build!!!
                            Now I use tape trimmed to fit on larger clear plastic and the liquid variety for smaller areas. I apply the liquid mask with a toothpick. Works a treat using that method.
                            • Geoffers
                              • Jan 2017
                              • 1751
                              • Geoff
                              I’ve been following your build Steve and I think it is coming along very nicely.
                              While you are getting used to masking it might be worth considering investing in pre-cut mask sets which would help you a lot.
                              Don’t be too down on yourself you are doing well and as some of the other guys have said you are learning and improving your skills as you go along :thumb2:
                              Geoff.
                                Geoff.
                                I'll certainly do that for my 1/24 Spitfire for sure.
                                as for my current model, today I've been painting and fitting the undercarriage and just now painted the prop and spinner.
                                I believe the next step is the decals. I can't remember if you use matt or gloss varnish before you add decals, but I'm sure someone
                                told me on my last build, so I'll go and read that.
