Tamiya 1/48th Scale Spitfire Mk Vb
    Been doing a bit more and just gave her a coat of gloss varnish. a couple of images for you.
    Looking at the decals now but.. I'm a bit puzzled, looking at the instructions some of the decals you put two on in the same place!?!
    surely that's going to be too thick?
ID:	1221867Click image for larger version
ID:	1221868Click image for larger version
    • Scratchbuilder
      • Jul 2022
      • 2689
      #62
      Originally posted by Waspie
      Better than my first attempt at canopy’s Steve!! Mine looked about a foot wide. See my 1/72 sea king build!!!
      Now I use tape trimmed to fit on larger clear plastic and the liquid variety for smaller areas. I apply the liquid mask with a toothpick. Works a treat using that method.
      It was exactly a foot, I sneaked in and measured it....
      • Scratchbuilder
        • Jul 2022
        • 2689
        #63
        Tamiya give you a white background to apply first and then the roundel over the top once the white has settled/dried. I would use a spare decal to check the thickness on an old bit of painted area - not the model. If it covers ok then it should be safe to just use the coloured decals. The Yellow/Red ones are for the wing leading edge and the red is supposed to cover the outboard gun ports, there are two styles, just choose the one you need. Or you could just paint the leading edge Yellow...
        HTH
        Mike.
          HTH
          Mike.
          Never seen two layers of decals before but fine, maybe it's a good idea. As for the yellow/red ones, I was quite happy when I spotted those because I didn't attempt
          to mask the leading edge of the wings and paint that in, I figured there was a good chance of messing it up, so was quite pleased when I saw the decals for them.
          I'll give those a go for sure. Thanks!
            • 18931
            HTH
            Mike.
            I’ve made a few Tamiya warbirds but have never come across that before either. Is it a new thing they’ve done on their more recent kits? I’ve seen/used several sets of decals where the red part of the roundel goes on separately, but not the whole marking.
              The Brewster I built a few years ago had white backgrounds for some of the decals too, as I recall mainly for the dragons on the fuselage in one of the British versions.
              • Scratchbuilder
                • Jul 2022
                • 2689
                #67
                I have only seen it on two of their kits, one was the Spitfire and the other was the F4U Corsair. And I am sure I still have a set of the Spitfire ones in my decal folder.
                • Scratchbuilder
                  • Jul 2022
                  • 2689
                  #68
                  Revell issued a white background to their Stuka with the dragon down the fuselage.
                  And just checked and I have three sets all the same, so if you get into any problems with them let me know.
                    Been very excited to start adding decals today but as i'm adding the first one.. I'm so annoyed. Decalfix is taking the paint off and this is after I gave it a gloss coat of varnish last night!!
                    New image added, I removed the decal and this is what decalfix did.. (I've just wiped it all off and resprayed that wing again) I guess I'll have to make do with no decals on it.
ID:	1221899Click image for larger version
                    • Easyrider5258
                      • Dec 2023
                      • 79
                      #70
                      I'm a new returnee as well and things have changed, I had a slight problem with Micro Sol and Set with white staining, but learnt not to react instantly and google the problem before taking any irreversible action, it was recommended that I just left my white stains and they would disappear, they did and after a matt coat was sprayed the decals now look painted on, I googled "Decalfix" and found similar answers to your problem, and of course with google you can get the solution much quicker than on here! ... it looks like you used a lot of solution? I just "paint" the solution on the decal only, don't flood it, are you using the best decal setting solution? Micro Sol / Set seem to be the way to go?
                        I think I … would not use Decalfix at all, if it does that to the paint on the model I’ve never had any problems with Micro Set and Sol, and would definitely recommend them instead of this.
                        • Waspie
                          • Mar 2023
                          • 3488
                          • Doug
                          • Fraggle Rock
                          #72
                          My congratulation at being the only human to get past the integrated security systems!!! Well the pup!!! Now do you mind returning my secret stash of Crunchies - they appear to have gone adrift - or did I eat them????
                          • Waspie
                            • Mar 2023
                            • 3488
                            • Doug
                            • Fraggle Rock
                            #73
                            Mmmm, re the decals. I haven't used anything other than warm water and cotton buds to affix decals. I am yet to move to the Sol and Set method! YET!!!!!
                              Well, last night I repainted that wing and then gave the whole thing two coats of humbrol acrylic gloss varnish. left it all night to dry and
                              just now I tried applying a decal using just water, no decalfix and.. it took the damn paint off my wing again!
                              I give up
                              • Scratchbuilder
                                • Jul 2022
                                • 2689
                                #75
                                I did not touch your crunchies, I remember leaving the wrappers next to your bed... ooops....
