Trying to have 1/72 fun with the 1940 McClellan- Barclay wacky camouflage schemes.
When they were actually tested in the air, the different blocks of colours tended to blur into one greyish shape.
I’m not all that surprised about that. The shapes seem pretty narrow, which won’t help to keep them visually distinct. This is also usually the major failing of the kinds of “camouflage” patterns you see irregular forces, rebels, etc. apply to their vehicles: lots of little dabs of paint that will just blend together with the background into one colour from a distance.
I was going to keep the underside kind'a simple, similar to the Buffalo, but I thought, Nah! So I gave my imagination free rein.
The overall exercise is proving to be a difficult one , but in a perverse sort of way I'm enjoying it. Even if "The shapes seem pretty narrow, which won't help to keep them visually distinct."
Here is the lower surface of the fighter. Totally off the wall!
Ha! Let's see if the smart a****d ground defences can look up and figure out just what this is and its course, height and speed!
Well Ron, If your good lady uses her excellent chucking up skills and you are fast enough with the camera, we could find out how well the camo works!!!...
This is what happens when you give Ron a cheap kit and some oop: paints. He builds it well and then paints it beyond belief! Nice one sir.
I read some place, probably in the Beano that Camouflage on aircraft was primarily to hide them on the ground. Lets face it an aircraft, in flight is a dark blob against a light sky.
Once that was figured out our 'Merican buddies gave up the paint and saved a good bit of weight (and cost/time which was put toward the extra maintenance costs.
Back on the topic.
A most excellent and entertaining thread Ron.
