Airfix 1/48 Canadair Sabre F.4
Yep, always fun when you don’t realise that the cap isn’t on :smiling3:
I’ll raise you one, though: Revell used to sell airbrush-ready paint that had a steel mixing ball in the jar. Steel balls and glass jars are not a good combo, though … I had two of those jars break in my hand as I was shaking them. Paint everywhere, big shards of glass in my hand, smaller shards on the floor, but luckily I didn’t cut myself. After the second, I dug the mixing balls out of all of the jars I had, and from any new ones I bought.
Oh, BTW, Tamiya paint really needs to be treated like you’re James Bond: stirred, not shakenIt will mix much better if you stir it with a flat stick — I’ve been using ice lolly sticks for that for 35 years.
Sorry for the laughing smiley!! (I really should stop seeing bad things as funny). I religiously check my Tamiya Thin now after knocking it - thinking the lid was on I didn't do my usual cricketers catch. Instead, for my slow realisation, I spent a good half an hour cleaning up the mess. I also discovered Tamiya Thin removes all the markings from your cutting mat!!!! Every day a school day. (Even at my age).Strength isn't about what you can do, rather it's about overcoming what you thought you couldn't do.Comment
Little update, close to the end now. Just masked/painted the canopy and the modelling work is pretty much done now.
I bought some Tamiya X-22 to clear coat it with (the Humbrol went in the bin after the last disaster)
I just need to do a little touching up around some doors etc before I do that.
I'm seeing some weird tiny white bits on the starboard wing, tried wiping it carefully with a cloth but it won't move. I'm tempted to try a little IPA but i'm scared of damaging the camo.
So the plan tomorrow is to do the touching up, glue on the canopy and then clear coat the whole thing ready for the decals.
To get rid of the white bits, I think I’d probably simply try drybrushing over them with the same grey you painted the camouflage with.Comment
Thought it was going too good. I've spent the last two full days painting the wheels over and over and over and over and.. well you get it.
I get the rubber black on the silver hub or silver on the rubber. I have painted them over eight times now!!
and quite frankly I'm at the edge of giving up again. How can it be so hard to paint WHEELS!?!!? Tried brush, tried airbrush but it makes no difference.
I'm losing my mind right now. I thought I was getting close to finishing this but the damn wheels have finished me.On the bench: Airfix 1/48 Sea King HC4, Revell 1/24 Trabant.
Just finished: Airfix 1/48 Stuka & Airfix 1/72 Sea King HC4.Comment
No update for a while as i'm still adding decals/stencils and I'm very very slow at it. I think there is over 120 stencils and quite frankly I'm losing the will to live adding them one by one and some of them are TINY! (see image!)
I will not give up though and I'll keep plodding on. images to come when it's done but I do have one question. Do you clear coat after the decals are all done and before you add any weathering or after the decals and the weathering is done?
[ATTACH=CONFIG]n1223328[/ATTACH]Comment
Well, I'm going to call this done.
So this is done, was it a good build? Well I mostly enjoyed building it and some of the painting. The decals/stencils were a royal pain
and the completed model? I'd give myself 4/10 - quite poor.
Was it worth all the time and effort put into it? ..being totally honest no, the final thing is a disappointment.
Again Steve, you’re being way too hard on yourself. It’s fine - honestly we are our own worst critics.
You stuck with it and finished it. That’s gotta feel good huh?
Stick with it my man, every one is better than the last. That’s the way it is. We build, we learn we improve.
You should be proud of your Sabre. Way way better than a measly 4/10.Comment
