Tworrs 1/72 Lancaster B.III
Strength isn't about what you can do, rather it's about overcoming what you thought you couldn't do. -
Strength isn't about what you can do, rather it's about overcoming what you thought you couldn't do.Comment
Also the 2 wing spars that protrude from the fuselage to which the wings are fitted splay a little when the wheel housings are added, I dry fitted and messed around with this section for some time before managing to force fit them.
That is all so far.
Not to worry I will make the little b*gger bend to my will. Haha I need bigger models these days so I can see what I'm doing :smiling2:Strength isn't about what you can do, rather it's about overcoming what you thought you couldn't do.Comment
HI Garry she lookin good an you say you also have fit probs seems to me they earnt makin the kit good nowadays like my tomcat fit problems as so far ive had a lot an glad you wernt hurt by them hailstones that size an did you have your car in a garage ?Comment
Yes, fortunately my car was in the garage and SWMBO's car was in the carport.Strength isn't about what you can do, rather it's about overcoming what you thought you couldn't do.Comment
Brilliant sunny day today, even though it was -2C this morning.
Todays progress.
The undercarriage is in, and what a mission that was, talk about fiddly, however I persevered and here is the result with which I am quite pleased.
Then installed the horizontal and vertical stabilisers to the rear of the fuselage.
That's all for today.
Thanks for all your encouraging comments.
GarryStrength isn't about what you can do, rather it's about overcoming what you thought you couldn't do.Comment
