In another thread 'boatman' requested seeing the build thread pics from my 145sqn Lightning T4.
This one was put together in around 2009 using Humbrol rattlecan acrylics and tinlet enamels
The Airfix F1a box art is one of my all time favourites
I can't find the before and after pics of these aeroclub Martin Baker Mk4 metal seats
I'll skip the sprue shots and on to the fuselage comparisons
As can be seen in this photo I modified the T55 vertical tail rather than use the ancient less accurate Airfix vertical tail.
Warpaint Publications no14 BAC Lightning was used for reference
I cut out the T55 ventral tank not only with a razor saw but also a Stanley blade
The ventral tank needs a little attention, Squadron Green was my filler of choice in those days
Didn't get the Airfix ventral tank cut right, needed a plasticard shim
Lots of quick drying Squadron Green
Rattle can Humbrol white to check for flaws in the finish
Sanding back the heavy Matchbox detail molding on the wings paint check then sand again. . . . ad infinitum
On to paint. . . .
On to paint. . . .
