Academy 1/72 F86 Sabre - my third build so far
    Thanks Michael,
    I'm putting this all down to experience, although it's disappointing to see it go ti#s up so near completion. This is why I'm doing 1/72 models which don't cost much. Strip and try again. Nail varnish remover didn't work, so I think I'll try Fairy Power Spray, which features quite a bit on Youtube
    Tony
      I got hold of some Fairy Power Spray, and it worked a treat as a paint stripper. The acrylic paint lifted away ridiculously easily, but the silver paint was a bit more tenacious. After a couple of hours of soaking and a scrub with a non-stick scourer it's gone.
      I've washed the model, so now I suppose I need to leave it to dry before prepare it for primer. I also need to stick the stabilizer back on that I broke off in the cleaning.
      • michaelm
        • Dec 2011
        • 437
        #18
        Well done for sticking with it Tony, there's quite a learning curve when you get into this. Metallics can be tricky as they are pretty unforgiving but I'm sure this will turn out great.
