HI GUYS well ive actually made a start on the hornet build as ive been dithering about where to start as dont want to start in the wrong place an find i cant fit in what i have planned on the build an the first part cut from the spruces was a side avieonics bay hatch cover an ive fitted in a hinge so the bay aviveonics will be able to be seen an lit up with a white 2mm led an can also be closed up postion an this side is on the practice side on port as the starboard side will be the show side an here it is bein fitted in some pics
AN for once the hatch cover is an excellent fit but very tight
an hinge is fitted may be a bit to big as this build will be like the tomcat warts an all
AN in the open postion an i dont think the hinge will be seen much as it will be right under the start of the wing an its got to be tidyied up an the hole there will be for the led wires to go through for the lightin
AN closed up again an this panel cover is so tight to try an open as i learnt on the tomcat how not to fit them but they all came right in the end but on this panel ive bent it slightly so i can get my nail underneath so i can open the panel cover up
an i will paint all the aveionics boxs an wires in different colours so it makes it a bit more instresting when lit up with lights
An here a shot of both front parts of the fusalarge an as can be seen there are avieoincs bays on both sides of the fusalarge an tommorow i will try an fit the the other panel cover on but maybe use a smaller hinge but if i do the smaller hinge may not keep the panel straight so may have to use another like i have on the port side an i must remember to fit it the 2mm white leds as i nearly did forget on the tomcat just remembered in time before i closed up the fusalarge havles stay tuned in for the next instalment lol
chrisb
chrisb
