I've been dying to get my hands on this so with a few projects out of the way I popped the cork
Plenty of crisply moulded plastic in the box:
So far everything has fitted together perfectly, but as with the Gannet I did recently, getting enough weight upfront is going to be a challenge. I'm not sure what substance Airfix are using but there was no way I was getting the required 30g into this section, even using lead shot, with liquid gravity to fill the voids between them
Lead strip in this area didn't get near the required 25g either
So I've been adding shot &
strip to every hidden open area I can. It's detracted from the fun a little but now that the cockpit and forward crew areas are finished, I've seen a few other nooks where I can add a bit more without it being too noticeable
So here we are at the moment. The nose & cockpit section is separate from the main fuselage and I've started masking up for painting the rear sections. There's plenty of debate around the actual colours but I'm sticking with the Airfix suggestions
