Hi all
The two FW190s crossed the finish line earlier this week (more about that later) and so as I'm holiday I got cracking on my next subject....this.
If this review (link) is anything to by then there are some serious shape issues, most notably around the nose, albeit this individual (link) was less worried.
Despite the issues, I have chosen this kit for a number of reasons:
And actually despite the issues, considering this is a 1995 tooling (albeit a 2012 rebox), I don't think the surface detail looks too bad!
I intend for this to be a 'quick and dirty' OOB build as the 190s took far too long and so I'm not even bothering to worry about the ejector pin marks on the bottom of the cockpit walls, as they won't be seen once buttoned up - so for those of you that hate them, look away now!!
The usual sprue shots are below, along with where I had got up to after a couple of hours earlier this week...and so far no major dramas.
Since I took the below shots, I've started to apply the paint...the cockpit green went on an hour or so ago.
ACW as usual!
ATB
For once a relatively tidy bench, following a major tidy up post the 190s!!
And the latest victim!!
- I'm not that fussed about inaccuracies....after all my first love is super simple wargaming kits!
- It's in the stash and so far I have never dumped a kit just because of some 'minor' inaccuracies.
- I won it in a charity raffle with ticket costing only 50p and so even if it is a bit of a dud, it's perfect practice for when I move onto the better quality 1/48 wingy kits in the stash....26 to be precise!
- Believe it or not I have only ever done one other Spitfire and so I thought I should change that.
ACW as usual!
ATB
