Typhoon TK-17 based on Engel's Kit
    :strong:
    euh well, edit seems to be noty possible so ask me question like you did and I will try to anwser
    the "Kabelverschraubung" (presse-étoupe, sorry english-people I don't know the word in your language... rusty I'am) were done with Metalworking lathes by me; thereis two Drive Shaft Sealing Ring 4-11-6 and one ball bearing on it :
      Today on my shipyard, reactor cooling exhaust !
      First, make a large hole on hull were i'll put a grid...
      Horizontal pieces...
      Inside, some rigid structure to obtain an stronger structure..
      vertical pieces wil be add later
        today, end of work of reactor exhaust grids
        Inside, there is still some work to do to get a better looking... just another sanding session :P
        After sending hull, there is much better looking !
        Globaly, I'm pretty happy, that look not bad ! Of course before painting this models will require a lot of corrections ! :thinking:
          I dont check in here often as I follow your build elsewhere, but once again a superb build and modifications to the original. You've raised the bar so much I bet you have put a few people off build an Engel Typhoon kit! :respect2:
            Totally agree! :sobbing::sobbing::sobbing::sobbing::sobbing:
            Heiko
              Well... i'm blushing
              Anyway...Today, I continu to add details on port side on the upper hull. Handrail, bolar...etc
              Drilling on starbord side, now sanding do fit with grid's size
