Special Hobby 1/72:nd scale Stuka . This one cost 20€ and it´s quite expensive even that there´s resin and photoetch-parts .
I mesure this fuselage Kagero Junkers book and there´s lot´s of wrong in the fuselage . It´s too short , wrong shaped after the rear canopy , also there´s some A1 look and A2 look at the same time
hno: . . . also canopy doesn´t fit the fuselage . . . so this one need´s more work then Academy´s Stuka .
I don´t fix the fuselage problems , just try to put this together easily . I add the cockpit some home made stuff , like wire´s and styrene bars .
Now the fuselage half´s and the cockpit are ready to paint RLM 66 inside color .
[ATTACH]16995.IPB[/ATTACH]
[ATTACH]16996.IPB[/ATTACH]
[ATTACH]16997.IPB[/ATTACH]
