P47 D Thunderbolt Construction 1/8th Scale
Hi Gang,
Back to the saga of the dreaded rotary engine, as you can recall... after deciding the Topflite effort was no good as the definition wasn't there i decided to make one out of wood. Well, after using the bigger engine it wasnt possible to get my creation to fit as the distance to the front of the cowl was diminished dramaticaly... so i whent back to the topflite effort and added some scale to it and it looked great. After the engine was fitted and the cowl fitted guess what. Yes still the problem with the depth. This time i have decided to fit the engine, backplate and cowl and am going to build the engine to fit in the gap available.
I set up the lathe and made a copy of a engine cylinder to the dimensions that i had taken. I then brought some Silicon moulding agent and some P U resin for casting and set out to cast some half cylinders. I will show you these as i have them, in the mean time this is my effort to make the engine crank case.
Andy
[ATTACH]19039.IPB[/ATTACH]
[ATTACH]19040.IPB[/ATTACH]
[ATTACH]19041.IPB[/ATTACH]
[ATTACH]19042.IPB[/ATTACH]
[ATTACH]19043.IPB[/ATTACH]
[ATTACH]19044.IPB[/ATTACH]
[ATTACH]19045.IPB[/ATTACH]
[ATTACH]19046.IPB[/ATTACH]
[ATTACH]19047.IPB[/ATTACH]
[ATTACH]19048.IPB[/ATTACH]
[ATTACH]19049.IPB[/ATTACH]
[ATTACH]19050.IPB[/ATTACH]
[ATTACH]19051.IPB[/ATTACH]
[ATTACH]19052.IPB[/ATTACH]
Hi Gang,
Andy
