P47 Thunderbolt construction
Well Gang, back again.
I have made some progress sindce the last downlaod, finnished skinning the wings. The process starts with the leading edge skin first and then the aft. We complete the bottom of the wing first and then the top. Before the top skin goes on you will see that we have to use the jig tabs supplied, this keeps the wing from warping. Critical error if missed. From there we move on to seperate the flaps. These are optional on this model bit i have built them in for better landing and take off control. Once the flaps are cut away a oblong leading edge is glued into place along with the contol horn. These have to be sculpted into shape with a razor plane and permagrit block. This was very fiddlie as you have to make sure that every thing fits we when ll in place and lines up with the upper wing skin. I have yet to complete the wing tips and the leading edge. You will also see, at the leading edge in the middle, the dowles that are required to retain the wing into the fuse. The servos are in place for the drop tank and the ailrons. I have cut the hatched for the flap servos and they are added later. I thought that once the skins have gone on we would be fibre glassing... Looks like i have a little more work to do before we get to that stage.
Andy
[ATTACH]17717.IPB[/ATTACH]
[ATTACH]17718.IPB[/ATTACH]
[ATTACH]17719.IPB[/ATTACH]
[ATTACH]17720.IPB[/ATTACH]
[ATTACH]17721.IPB[/ATTACH]
[ATTACH]17722.IPB[/ATTACH]
[ATTACH]17723.IPB[/ATTACH]
[ATTACH]17724.IPB[/ATTACH]
[ATTACH]17725.IPB[/ATTACH]
[ATTACH]17726.IPB[/ATTACH]
[ATTACH]17727.IPB[/ATTACH]
[ATTACH]17728.IPB[/ATTACH]
[ATTACH]17729.IPB[/ATTACH]
[ATTACH]17730.IPB[/ATTACH]
[ATTACH]17731.IPB[/ATTACH]
[ATTACH]17732.IPB[/ATTACH]
[ATTACH]17733.IPB[/ATTACH]
[ATTACH]17734.IPB[/ATTACH]
[ATTACH]17735.IPB[/ATTACH]
[ATTACH]17736.IPB[/ATTACH]
[ATTACH]17737.IPB[/ATTACH]
[ATTACH]17738.IPB[/ATTACH]
Andy
