Next aircraft under way, I still hate masking canopies so I don't know why I keep putting myself through this....
Anyway, I didn't do the box and sprue pics this time as I was too keen to get building.
Not a bad kit, my first proper modern jet kit and I have to say I have found it a bit complex in areas trying to work out where some of the bits go and how they should fit. Instructions not to clear in places. As ever with jets like these, the intakes at the front need to be smooth and clear, the fit on this kit isn't too good so a bit of filling and sanding as they are a bit of an eye puller.
As mentioned before, but repeated here for continuity, the canopy comes with a thick mould line right down its back. I was very nervous about sanding and re-polishing this but it didn't go too bad apart from getting a small crack in the canopy while putting bluetak in to protect it (!)
Only thing I have altered is is the APU (Auxillary Power Unit) exhaust. On the model it is an indentation on the port side of the fuselage just above the wing root. There is a resin modification for this which involves cutting out the indentation and fitting the resin part underneath which results in a pipe coming through the indentation. I drilled it out and cut a piece of sprue. I then sanded the sprue to fit the hole where the indentation was and I then drilled out the sprue. This was glued in place and 'blended' using liquid cement. Looks not to bad and cost nothing.....
Picies so far.
[ATTACH]21759.IPB[/ATTACH]
[ATTACH]21760.IPB[/ATTACH]
[ATTACH]21761.IPB[/ATTACH]
[ATTACH]21762.IPB[/ATTACH]
[ATTACH]21763.IPB[/ATTACH]
[ATTACH]21764.IPB[/ATTACH]
[ATTACH]21765.IPB[/ATTACH]
[ATTACH]21766.IPB[/ATTACH]
Picies so far.
