Royal Navy Phantom F-4K
    Hi All, For my next project I am building the 1/48 Hasegawa Royal Navy Phantom F-4K, I am going to make it the 001 serial XT858. In 1969 this Aircraft held the world record between New York and London when it took 4 Hrs 46 Min. I photographed it at the then RNAS Lossiemouth that year, see photos attached. As you may know in 1974 the SR-71 Blackbird beat the record by doing it in an unbelievable 1 Hr 54 Min 56.4 sec.
    It will be a slow build as the BOSS is dropping heavy hints about some DIY, so better take some action before the thumb screws come out. As the Cockpit is such a prominent feature on the Aircraft I have invested in an Aires Cockpit Resin Set, never used them before, but they seem to have a good reputation and they certainly are very detailed, see photo attached. Thanks Derek
    [ATTACH]22201.IPB[/ATTACH]
    [ATTACH]22202.IPB[/ATTACH]
    [ATTACH]22203.IPB[/ATTACH]
    [ATTACH]22204.IPB[/ATTACH]
    [ATTACH]22205.IPB[/ATTACH]
    [ATTACH]22206.IPB[/ATTACH]
    [ATTACH]22207.IPB[/ATTACH]
    [ATTACH]22208.IPB[/ATTACH]
    [ATTACH]22209.IPB[/ATTACH]
  • yak face
    • Jun 2009
    • 13826
    • Tony
    hi derek .this is going to be a great build,im really looking forward to seeing how it develops. Like yourself ive never used one of the resin cockpits, but ive always liked the look of them.Really useful when the cockpit is as visible as this. cheers tony
      Hi Tony, Thanks, what are you working on just now?, looking forward to seeing your next winged creation. Derek
        Have you thought of hitting your foot with a hammer? Can't do DIY with a broken foot but ya can still build models, therapeutic even.....
        I love the Phantom, I think it is one of those rare aircraft that actually looks like a killing machine, the A10 is another. Look forward to watching this grow. Never used the resin sets before but I have seen what can be done with them. Any tips along theway re resin will be much appreciated. By the way, you are aware that resin dust is considered very toxic? Try to clean up with a damp cloth to prevent airborne dust particles.
          Hi Graham, Thanks for the info, I knew the Forum was packed with info, but getting out of DIY - well what can I say. If the hammer doesn't work maybe the dust will get me. Seriously though, thanks for the interest, and yes the Phantom with the Spey engines looks the business, they were fantastic on re-heat Derek
          • yak face
            • Jun 2009
            • 13826
            • Tony
            At the mo ive got 4 in progress- The 1/72 desert dio with hans joachim marseilles bf109 and kubelwagen(the plane and kube are done im just battling with the base), the 1/72 p40e warhawk in captured japanese markings (see thread-"someone must build this colourful p40e") , 1/48 yak 9t and finally a 1/72 fieseler fi 167.A real pick and mix eh!!! cant wait to see the spook ,always had a soft spot for the big phantom,i remember seeing a quote from an american general ,who on seeing the first phantom said it looked like it was flying upside down! cheers tony
              Hi Derek this looks like it will be a cool build, i love the cockpit detailing hope you keep posting the pics.
              scott
                Hi Tony, What do you do with all that spare time on your hands? I knew you had a factory admit it. Seriously though, look forward to seeing some pictures.
                Hi Scott, Will do, one thing you definitely need is a Razor Saw for the Resin parts, as there is a lot of material to remove. Another thing I have found is the models plastic area around the nose and cockpit needs significant surgery to fit the cockpit tub. I have the cockpit tub parts prepped, will post some photos when it is finished painted.
                Thanks for your interest Derek
                  Hi Folks, Have made some progress this week on the cockpit tub, see photos below. Have cut the Aires Resin parts and cleaned them up, and painted the basic components. There is a lot more to add but will leave these off until after the main aircraft painting is finished. Have included a shot of the basic Aires cockpit tub against the one provided with the kit for comparison. The cockpit dials are the usual film and PE, have used these before at 1/32 scale but the 1/48 scale is quite difficult to handle. I always paint the plastic white before I apply the film to make the dials more prominent. You need a lot of guess work as to how the Aires cockpit tub is going to fit into the fuselage as it is not a direct substitution, a lot of surgery is going to be needed. That's all for now Derek
                  [ATTACH]22369.IPB[/ATTACH]
                  [ATTACH]22370.IPB[/ATTACH]
                  [ATTACH]22371.IPB[/ATTACH]
                  [ATTACH]22372.IPB[/ATTACH]
                  [ATTACH]22373.IPB[/ATTACH]
                  [ATTACH]22374.IPB[/ATTACH]
                  • yak face
                    • Jun 2009
                    • 13826
                    • Tony
                    superb looking cockpit derek,such a difference from the kit one. You must be leaving the canopies open to display all this detail cheers tony
                      That cockpit detail is fantastic mate, good luck on the surgery.
                      scott
                        Hi Tony and Scott, Thanks for viewing, discovered a MAJOR problem last night. Have not been able to dry fit the cockpit tub until the raised section at the front of the fuselage, also the cross beam half way along and the flat at the back of the cockpit is removed, see photo. Did this last night and found that the cockpit tub sits 3mm too high. The tub sits on top of the nose wheel well so no room for manoeuvre there. Cut off 3mm form the tub underside which unfortunately also removed the floor of the tub at the front seat location. Will have to cobble something up, in the meantime if you know of any Phantom Pilots 4ft tall, tell them I have the exact aircraft for them. Upwards and onwards. Cheers Derek
                        [ATTACH]22388.IPB[/ATTACH]
                        • yak face
                          • Jun 2009
                          • 13826
                          • Tony
                          hi derek , i understand thats a common problem with resin cockpits ,wheel wells etc. i suppose its the trade off for having all that lovely detail! Ive read of cases where people have ground out the plastic that thin, its nearly see through!! Im sure youll conquer it ,and if the floor is a scale 6 inches too high ,i dont think anyone will notice (only maybe the scale pilot!) cheers tony
                          • Gern
                            • 9211
                            I'm back again with a stoopid question!
                            If the makers resin cockpits can get them so finely detailed, how come none of them actually fit the 'plane they're made for? Seems that every review/build I've seen which uses these, some modification has to be made. In some cases it's really drastic as Tony says.
                            Gern
                              Hi Tony and Gern, Thanks for your input. On researching the problem it would appear that Aires do a special wheel well which allows a correct fit of the tub?? So if anyone is thinking of using an Aires cockpit look to see if they do a wheel well also, that's maybe the answer to Gern's query. For me I wouldn't bother again, by the time you buy that lot you have doubled the price of the original kit, I'm not that much of a puritan. The Hasegawa Phantom cockpit is very poor however so I will persevere with the Aires cockpit. By comparison my next model will be the Hasegawa 1/48 Starfighter TF-104G and its cockpit is much better (gives the option of painting the raised detail or use Decals) although strangely enough from the copyright mark the phantom is the newer kit, probably an older re-release in disguise. Cheers Derek
