Hasegawa F6F-3 as voted for by you!
    Dunno what to do about that decal
    Have I missed something? What happened to what decal????
      one of the oval prop manufacturers decals came off wheni masked for the chrome spinner (even under a coat of Klear) ... it's absence is present (or vice versa - its prescence is absent) in the last photo...
        Ahhh, see what you mean, although I didn't... if you catch my drift. Could you not do a bit of red and yellow paint to represent it? Or maybe it has writing on, I cannot tell from the pic.
        EDIT Or, I have 4 of these and only need 3 so I could send you one if they look similar, they are a tad more yellow than they look in the pic but not as strong as yours look.
        [ATTACH]23932.IPB[/ATTACH]
          The writing is miniscule - unreadable to me naked eyes... good plan about the paint, maybe under a layer of weathering I'd be able to pass it as a decal... I'll give it a go and see where I land,...
          Finished masking the canopy. Gunsight and armour glass is fixed in position and glue is drying. Tomorrow after work, canopy will be glued and primer coat on hopefully.
          Stuart
            That'd be great Graham - even if it's slightly different it's better than having no decal on one blade! Thanks a million :no1b:
              No probs, can you PM your address and I will get it sent up for you.
                PM inbound! Cheers Graham - true Gent!!
                  No probs mate, will be in tomorrows post.
                    Right, so the result of an evening's worth of swearing, wrestling, re-masking, gluing and trying not to break anything, is now something that resembles an F6 - canopy and tailplanes are on, tailplanes are drying now, so primer and - depending on the PSR requirements - maybe first coat of white underside due for this evening! Pics to follow
                    Stuart
                      Ok then.... 1st primer coat and some filler. As you can see, there is no need for much - well done Hasegawa!
                      The main concentrations are the upper nose joint, lower rear fuselage joint and the wing leading edges. I think I may only need one round of PSR (famous last words!!)
                      Photos
                      Comments welcome
                      Stuart
                        Decal has been posted today Stuart. Looking good mate. Detail on the Hasagawa look as good as the Eduard, this is going to be good. Have to say though, I don't envy you the three colour scheme. Blending the white into the light blue and then into the dark. Is it soft edged or hard? Looks fairly soft from the pictures I have seen. Err, what is PSR?
                          Excellent cheers - so prop aint far away now It is soft....which is slightly annoying. I'm thinking white 1st, then for the blues, lots of thinner and not a lot of pressure around the edges, I have a dual action airbrush so hope that'll ease the pain slightly.
                          PSR = our old friend Putty Sand Repeat!
                          Right - I'm off to rub it down and get another blast of primer on it!!
                          Stuart
                            Ok, so I hate painting things white >
                            I put a light coat on the underside just to get started and I've now got the wingroots filled and the pre-shading done on the sides and underneath
                            ...And thanks to the generosity of a most kind Graham, I now have 3 decals on my 3 prop blades, the way it should be ( I lost one to the masking tape monster y'see)
                            Stuart
                              Glad it got there safe Stuart, looks OK to me :-)
                              Builds coming on nicely. I have done nothing over the Bank Holiday weekend due to other commitments. Also been out to Woburn Safari Park today, great day out but nothing model worthy lol.
                                I've not done a lot either tbh - too busy working, doin bank hol things with t'other 'alf, and trying to get a build for my bro close to finishing (KC-135 1/72 in 2 tone Grey scheme - masking nightmare), but I think another 1 coat of white on the 'Cat and that's the 1st of the 3 tone finished
                                Stuart
