1/24 trumpeter FW 190 D9
    Weathering completed
    Hi folks the weathering on the engine and cockpit are done as far as iam concerned, will still be adding little bits to the engine as we go so hope you like the progress so far.
    scott:gooddoggy:
    [ATTACH]25088.IPB[/ATTACH]
    [ATTACH]25089.IPB[/ATTACH]
    [ATTACH]25090.IPB[/ATTACH]
    [ATTACH]25091.IPB[/ATTACH]
    [ATTACH]25092.IPB[/ATTACH]
    [ATTACH]25093.IPB[/ATTACH]
    [ATTACH]25094.IPB[/ATTACH]
    [ATTACH]25095.IPB[/ATTACH]
    • AlanG
      • 6296
      #17
      Lookin mighty fine Scott. Excellent work so far
        Sat here drawling at this build mate, totally awsome, all the best Martin :-)
          Great model. I liked what you did in the engine. Keep up the good work.
            Cheers for your comments gents next post will follow in a day or two.
            scott
              Scott, Wow it only gets better, I have my 5 Stars on standby already. Must be really satisfying to make this kit. Cheers Derek
                Hi Derek this is slow going but yes it is very satisfying ive had to do some major surgery to the fuselage because the kit dosent allow you the opportunity to open up the engine cowlings to view the engine so a bit of cutting had to be done.... nerve racking i'll tell you considering the kit cost ยฃ70.00, thanks for viewing more in a day or so.
                scott
                  • 18272
                  Wow that looks great!
                  Cant understand why they would make a kit in that scale with so much detail in the engine then not have a cowl that can be open? Weird!
                  Keep at it Scott
                    Cheers i have moved on a little and will post the pic this afternoon.
                    scott
                      Dora build
                      Hi guys ok for those following this thread i have managed to do a little more, first as stated there was no way to be able to show the engine off so i have had to do so surgery by cutting away the front engine cowlings. I can tell you i was sweating and my hands were shaking here because if this got messed up i'd be putting it in the bin.
                      After i cut away the cowlings i mounted the cockpit and the engine into the fuselage, and i have to say this kit is fitting together nicely so far, i then set to on the wing guns and the inner wheel well area which was attach to the inner wing the landing struts were also partly assembled, these will have springs inside them so the struts will move. The next stage will be the control surfaces and the wing and the surgically altering the cowilngs to an open position but thats to come later hope your enjoying the build more soon.
                      scott
                      [ATTACH]25179.IPB[/ATTACH]
                      [ATTACH]25180.IPB[/ATTACH]
                      [ATTACH]25181.IPB[/ATTACH]
                      [ATTACH]25182.IPB[/ATTACH]
                      [ATTACH]25183.IPB[/ATTACH]
                        further progress
                        Here is some further pics of the progress iam making so far the engine cowling covers have been altered but as yet not cleaned up, the drop tank is completed and the interior of the canopy is in due process, so far it is going quite well so fingers crossed.
                        scott
                        [ATTACH]25198.IPB[/ATTACH]
                        [ATTACH]25199.IPB[/ATTACH]
                        [ATTACH]25200.IPB[/ATTACH]
                        [ATTACH]25201.IPB[/ATTACH]
                        [ATTACH]25202.IPB[/ATTACH]
                        [ATTACH]25203.IPB[/ATTACH]
                        [ATTACH]25204.IPB[/ATTACH]
                          Good plan, would have been a crime to hide that engine.
                          • AlanG
                            • 6296
                            #28
                            Anymore progress with this Scott? Reason i'm asking is i have a chance to buy one lol
                            • tr1ckey66
                              • Mar 2009
                              • 3592
                              #29
                              Hi Scott (sorry I missed this) excellent work on the Dora engine and cockpit. This is going to be one stunning looking bird when finished!
                              All the best
                              Paul
                                Scott that is truly looking awesome!That engine work is spot on great job
