Revell 1:48 Mosquito MK IV
    Lovely paint work and the dry brush detail work is great
    • colin m
      • 8763
      • Colin
      • Stafford, UK
      #17
      I just wondered how this one is going ? I'm currently building a Revell kit which is actually on old matchbox mould and the fit is challenging ! I'm hoping your Revell is maybe a new moulding and so a good fit. Have you stuck anything big together yet ?
      Regards
      Colin M......
        I have the fuselage together, pics later. This is a fairly new tool Revell kit Collin. Some of the older Matchbox kits were a bit troublesome but stick with it as you will get a good result if you take your time and work on it.
          Bit of a dilema. I have been scouring the net (not always a good idea if you are not exactly sure what you are looking for) and I have found pictures of the Mosie bomber with black underside and sides but with dark green/dark earth camo, as on the Lancaster. I have also seen it in the kits colours of Grey/green camo with black sides and under. Given that I know that sometimes kit callouts are not always the best source of info, which would be right? This is 627 Sqn January 1944. Now i know that fighter command dropped the earth/green not long after the Bob but Bomber Command kept it through the war, never seen a Lancaster in green/Grey yet! Can anyone confirm that the black/dark Green/Ocean Grey is correct please?
          • stona
            • Jul 2008
            • 9889
            #20
            Graham as you no this isn't my area of expertise (educated guessing anyway) but by this time Mosquitoes were being produced in the DFS with grey/green upper surfaces and the black lower surface was an adjustment to that scheme. I'd be surprised to see dark earth/green upper surfaces at this time. In my limited references none of the Mossies seem to have this scheme.
            My computer is mis-behaving but I've got everything on an external hard drive,I'm sure I remember saving some Mosquito related painting orders and if I did and if they are relevant I'll post them in the morning.
            I'm on my own computer now,hope it holds out! I couldn't find that document but found a few piccies. They are all definitely Ocean Grey/Dark Green over Black (Night). I found two piccies of 23Sqn. Mossies which I must have found on T'interweb which clearly show this. The only question would be the style of the demarcation.
              Thanks Steve. I have seen a pic on the internet where the Mosquito was dark earth and green and I am just about convinced that the bomber, those two in the pics are fighters, would have been grey green. I was really wondering why the Bomber command stayed with earth/green and didn't go over to grey green like the rest. I assume that the Mosquito bombers would have come under bomber command as they were mainly used as pathfinders and special one off jobs. Given that, I just wondered why they were not painted the same as Lancasters. I really should just build the kits and not think about it lol.
              Thanks for the tip re canopy masks Colin, they arrived in the post today and there is lots of them on a small sheet. O happy days lol
              • stona
                • Jul 2008
                • 9889
                #22
                Hi Graham,the reason fighter command introduced the day fighter scheme,DFS, (grey/green uppers) had nothing to do with operating over the channel as is often said but was because the earlier brown/green scheme was beginning to be a liability at the increased altitude at which the fighters were operating. The DFS was seen as a compromise giving better camouflage at altitude whilst still affording protection on the ground.The grey,though considered a compromise, is not so daft on the ground as around RAF aerodromes of the time the aprons,taxiways and revetments were almost invariably concrete.
                I have seen,but can't find,a 1941 document which specifically notes that the Mosquito will be finished in the new DFS.
                The aircraft of bomber command operated largely at night where aerial camouflage comprised the black lower surface,the colour of the upper surfaces being irrelevant. All cats are grey in the dark! The dark earth and dark green upper surfaces were kept as they were considered to afford better protection on the ground,no compromise required.
                Whether the Mosquito had grey/green or brown/green upper surface camouflage would make no difference at night whereas during daylight,at altitude,the grey/green would be advantageous.
                I did find this.
                "I believe that only the first few Mosquito bombers with the short nacelles were finished in the Dark Green Dark Earth sky scheme. These aircraft were called B MkIV series 1. I haven’t got my references with me but not too many were produced before production shifted to the long nacelle version B MkIV series 2. As far as I can ascertain these aircraft were all finished in the day-fighter scheme, including sky spinners and sky fuselage band. These original machines were allocated to 2 Group Bomber Command as day Bombers.
                2 Group was subsequently transferred to Fighter Command but the Mosquito Bomber squadrons transferred to 8 Group and started to fly at night. The sky bands and spinners had by this time stopped being applied to the Bombers, but they remained in the day fighter scheme with some units applying black under surfaces."
                I also found this.
                "In early 1942 it was realised by the Air Ministry that as the Mosquito operated in many different roles many different camouflage schemes would be applied to them on the production lines of the factories. It was mooted that all Mosquitoes, whatever their operational function, should be finished on the production lines in overall MSG. The service camouflage schemes could then be applied to the aircraft after they left the production lines either at the factory or at ASUs (Aircraft Servicing Units). The suggestion was adopted on the 12th March 1942."
                As a foot note it is interesting to see how Lufwaffe camouflage reflects the same themes. Bombers and transports were always in a green scheme for ground concealment. Fighters,by late 1941were in greys for altitude protection. Fighters operating on the eastern front,operating at lower altitudes,quickly revised their schemes to green and green/brown colours like the early British schemes. At the end of the war,when the air superiority of the allies made concealment on the ground vital,the Luftwaffe fighters adopted green,grey/green,and green/brown schemes.
                  Once again Steve, you have excelled yourself and answered my ponderings perfectly. very informative and concise information. I will now do it Alclad chrome lol. Thanks a lot mate, don't know what we would do without you.
                    As I have said in my GB thread, a poor show in the modelling work for the last few weeks, I just have not been able to get stuck in and I really need to get on with things. Once again my report says "Must try Harder"
                    A bit of an update on the Mosquito.
                    Don't know if it is me or the kit but there are times when I could just put it in the box and forget it (I really do think it is me and not the kit).
                    Anyway, I have the main wings on, just a little filler needed on the roots but not much, certainly no putty, either Mr Surfacer 500 or even thick paint will fill it. The way the engine come undercarriage bits fit to the wings ( I cannot remember the correct term) are a bit of an oddity. The kit comes with two merlins that can be displayed by cutting out the panels, there is no alternative open or closed on this kit. Everything is closed and if you want it open then you get the knife out. This goes for the wheel doors and the bomb bay as well as the engines.
                    The trouble is that the nacelles (that's the word I was looking for) are part separate and part wing moulding. They have to be 'formed into position, there is no real location tabs or points. This in itself is OK, but the nacelles are very thin (nicely done as well) and without the engine panels in place a tad wobbly, if you get my meaning. Also, the construction method is that you place on half of the nacelle on the wing and then build up the engine supports, the engine and the undercarriage legs before placing the second half of the shell on. Very odd and making painting almost impossible. So I have had to do a workaround and I have decided that I will only have one engine on display, leaving me with a very nice Merlin that I might try to fit into the old Airfix Hurricane model.
                    So, I have glued together one nacelle (can't stop using that word now I remember it) leaving it empty. The other, I have cut out the engine panels and glued the halves together with the rear undercarriage wall. I will now have to paint the interior colour on the undercarriage wells and the open engine section as well as the supports for the engine and firewall. When this is dry I will then have to glue the engine to it's supports and thread the the engine and firewall assembly into place, I have tried a dummy run of this and it looks possible. Once this is done, the completed nacelles will have to be fitted to the wings and pray that I can still get the undercarriage legs in afterwards. Then the cut out engine covers are going to go back on held by tape inside and blue tack so that the outside can be painted without affecting the engine. Same goes for the bomb bay doors and wheel well doors and the crew hatch. This will allow me to paint the damn thing on the outside.
                    Anyway a few pics of what is happening so far.
                      • 18271
                      Looks like you are winning to me. Know what you mean about motivation. Some times I just look at things and think "I wonder if there is anything on the telly"?
                        Lovely detail around the control surfaces on this model. I'd like to know how this stacks up against the Airfix 1/24th version and see if the Airfix one is worth the extra expense.
                          Always difficult to establish if a kit is worth the money. The 1:24 Mosquito is very expensive by any standard but, it wants for nothing. From what I have seen of it, it is well worth it if you can afford it and have the space for it. I cannot afford it and I do not have the space for it so problem solved for me lol
                            Just about managed to get the engine into the starboard nacelle and have it clamped up trying to blend it all into the wing. Was it worth the effort? Not sure as there is not a lot of engine showing lol.
                            Anyway, after studying the instructions for ages as I thought the exhausts looked decidedly odd pointing skyward, I have attached them as per the instructions (see pic in post 24 above). Since then after looking at some pictures, I now find they are upside down, damn those instructions, they definitely show them pointing up...... AHHHGGGG... Anyway, they are covered up with bubble covers so they could not be seen at night so if I cannot retrieve them to turn round, then they will not be seen........
                            Just off to bang my head against a brick wall for a bit pictures later :shoot:
                            • stona
                              • Jul 2008
                              • 9889
                              #29
                              Looks like it's coming along nicely Graham. Do the flame dampers still fit over the exhaust pipes? I know what you mean about instructions some of them should be called distractions!
                                Originally posted by \
                                Do the flame dampers still fit over the exhaust pipes? Steve
                                They will Steve, by God they will. Anyway, I have managed to rip them out and put them back the right way up.... Having said that, looking at the parts for the dampers, they look no where near deep enough......... This kit will not beat me........
