Returning 1st build - 1/72 Airfix Wildcat
  • Centurion3RTR
    • Jan 2009
    • 2093
    #16
    Now that Neil is looking very nice, from what i've seen on the net they look matt. Someone will let you know better though matey.
    Have fun, John
      Thanks, Richard.
      Yeah, John, I would have guessed they'd be matt, but you never know with the navy !!! Time to bite the bullet and crack on with that undercarriage......
      Cheers, Neil
        Ok, after a lot of fiddling and a few false starts, one of half of the undercarrage is made. It's nowhere near perfect, but I think it's a lot better than the kit parts, though tbh, that wouldn't be hard!! It should be a bit better once it's all painted up. I may have to leave it a while before I attempt the other side, just to let my eyesight return...
        [ATTACH]24764.vB[/ATTACH][ATTACH]24763.vB[/ATTACH][ATTACH]24762.vB[/ATTACH][ATTACH]24761.vB[/ATTACH][ATTACH]24760.vB[/ATTACH][ATTACH]24759.vB[/ATTACH]
        Cheers, Neil
        [ATTACH]31085.IPB[/ATTACH]
        [ATTACH]31086.IPB[/ATTACH]
        [ATTACH]31087.IPB[/ATTACH]
        [ATTACH]31088.IPB[/ATTACH]
        [ATTACH]31089.IPB[/ATTACH]
        [ATTACH]31090.IPB[/ATTACH]
        • stona
          • Jul 2008
          • 9889
          #19
          Well done with those undercarriage struts/supports,it's a hell of a fiddly assembly.
          As far as the paint finish goes they left the factory gloss but quickly and progressively weathered to a matt finish. This means you can't go wrong lol!
            Thanks Steve, fiddly is one word for it, but a few others were used !!!
            And I'll take your comments on the finish as gospel if you don't mind, and just see how it turns out - I suspect it'll turn out newer rather than older, but we'll see.
            Now for the other side..........
            Cheers, Neil
            • yak face
              • Jun 2009
              • 13836
              • Tony
              #21
              Great job on the undercarriage neil, excellent stuff, cheers tony
                Right, both sides done and painted. I've included what comes with the kit as standard, so I think I've made a bit of an improvement !!
                They look a bit rough this close up, but not too bad from a bit of distance, so I just won't get that close then...
                Apologies for the quality of my pics, my photography is nearly as bad as my modelling !!!!
                .[ATTACH]25030.vB[/ATTACH][ATTACH]25031.vB[/ATTACH]
                [ATTACH]25026.vB[/ATTACH][ATTACH]25027.vB[/ATTACH][ATTACH]25029.vB[/ATTACH][ATTACH]25032.vB[/ATTACH][ATTACH]25028.vB[/ATTACH]
                Cheers, Neil
                [ATTACH]31319.IPB[/ATTACH]
                [ATTACH]31320.IPB[/ATTACH]
                [ATTACH]31321.IPB[/ATTACH]
                [ATTACH]31322.IPB[/ATTACH]
                [ATTACH]31323.IPB[/ATTACH]
                [ATTACH]31324.IPB[/ATTACH]
                [ATTACH]31325.IPB[/ATTACH]
                  Great craftsmanship. I am thoroughly enjoying the process.
                    If this is all about a return to modelling you are doing an excellent job of this. Don't forget you are not doing it for our benefit you are doing it for yourself so the most important part is whether you are enjoying it or not.
                      Many thanks for the comments, they are much appreciated, although I think "craftsmanship" is a tad much, compared with some of the work on here !!
                      I am enjoying it very much. I'm tackling things I've never tried before and I find posting on here is a good source of motorvation for me, as I'm prone to starting and not finishing things - continuing the thread kind of keeps me focused, if you see what I mean.
                      The only part's that are frustrating is the time that it's taking, and the lack of a dedicated area to do stuff, but there's not much I can do about either right now, so I'll just have to keep plodding along !!
                      Thanks again, lads.
                      Cheers, Neil
                        Hello again, a small amount of progress. Got the undercarrage in and glued, added the walkways to the wings, and after an "interesting" session, managed to sort the brackets for the gear doors, such as they are!! Quite happy with the result of these, I think once the doors themselves are on it should look ok.
                        [ATTACH]25066.vB[/ATTACH][ATTACH]25065.vB[/ATTACH][ATTACH]25067.vB[/ATTACH]
                        Cheers, Neil
                        [ATTACH]31358.IPB[/ATTACH]
                        [ATTACH]31359.IPB[/ATTACH]
                        [ATTACH]31360.IPB[/ATTACH]
                        • yak face
                          • Jun 2009
                          • 13836
                          • Tony
                          #27
                          Keep at it neil , its coming on great, I love to see good scratchbuilding ,especially when its bringing an old unloved kit up to modern standards of detail, wicked!! cheers tony
                            Hi all....a quick question.......I've masked off the panels behind the cowling where the exhausts exit and was going to try and paint them some mix of metallic paints, but I'm thinking I might experiment with a bit of ali foil. It's just the regular kitchen stuff and looks quite thin, and may give a better idea of the panel.
                            My question is what to glue it with? I don't really want to use CA in case I make a pig's ear of it and want to remove it ( quite likely ! ), but I'm not sure pva will do it? Any opinions?
                            Also if anyone has any better idea's of what to use, I'd love to hear them.
                            Cheers, Neil
                              Now, don't fall off your seat's chaps & chapess'........but I think I've actually finished this !!! I've included one pic here, but will post the rest in the Aircraft Pics section.
                              Many thanks for all the help and encouragement.
                              Cheers, Neil
                              [ATTACH]29052.vB[/ATTACH]
                              [ATTACH]34515.IPB[/ATTACH]
                              • AlanG
                                • 6296
                                #30
                                Looks great Neil. I'd be well chuffed with that
