KI 61 Hien Hasegawa 1/32
    The black "anti-glare" painted.
    The model is painted. I am waiting for the paint to dry for, with a rubber, can take the maskol.
    • stona
      • Jul 2008
      • 9889
      #17
      Very nice Antonio. I'm looking forward to seeing some extreme weathering on this one!
        Model painted. Maskol removed. Following is the wear on the paint, oils.
          Nice work Antonio.
          Adrian
            Lights and shadows. The lights were a little more because the lights in the application of oils tends to disappear. Indeed it is already the second time I apply the lights in the model. In the first and after applying the lights. I used oils. I do not know the name of the process. I applied a few drops of yellow oil, light green and dark and a light brown. I spread everything. It was not bad but the lights disappeared. Let's see how it will look like after applying the oils again.
              • 18269
              Antรณnio; Your POST SHADING is looking brilliant.
              It is always a joy to see youre work. I do not know if it is inspirering or depressing! Nope deffenently inspirational.
              I might just have to try some of the tricks you use and see how it goes.
              Love it!
                • 18269
                Originally posted by \
                Maskol applied with a sponge.
                Ok I have a silver airplane, I've dabbed maskol with a sponge..... Then I guess I paint it the top colour. How do you remove the paint/maskol to reveal the 'metal' underneath?
                  Just rub it off Ian, gentle with a soft pencil eraser for the its that don't come off easily, although maskol does rub off quite easily. Just have to be careful not to 'scrub ' at it, though you shouldn't have to. Just give it a go, you will soon realise how it comes off easily.
                    Just like Fenlander said.
                      This is the state of degradation where KI is. The fuselage is not ready yet.
                        That is really impressive............. I've dabbled a bit with weathering on the MB200 I'm building........... You have that "spot on" ........ Thanks for sharing it with us
                        Peter
                        • tr1ckey66
                          • Mar 2009
                          • 3592
                          #27
                          Another outstanding piece of work Antonio. You must have quite a collection of 1/32 aircraft now. It would be nice to see more of your work, I'm certainly a fan.
                          All the best
                          Paul
                            Finally the requested material has arrived. Eduard mask...
                            PE with the Eduard seat belts...
                            and decals from Life Like. One thing I learned. Never start a model without having all the material. I have just discovered that the wings have a white band and the antenna will disappear. As I painted the model with the X-11 Tamiya do not know whether to use tape on it will not pull the paint. Let's see how it goes out.
                              White stripes painted.
