Hi All, Re my last posting, a spare piece of canopy from my F16 was dipped in Klear and left for 48 Hrs to dry/cure, I then super glued a piece of scrap PE to it, and am pleased to report there was no damage to the surrounding area of the canopy from the super glue vapours, so this is the route I will take. Have cut out the PE for the canopy, still to shape it.
Have cut the Aires Resin parts for the exhaust and dry fitted them, and all seems to fit O.K. Am using the Airfix bulkhead for the airfix exhaust to reinforce the fuselage, the Aires exhaust still fits.
Problems when presenting up the air intake casing to the fuselage (see photo B20), if you line up the nose wheel bay with the fuselage there is a big misfit at the tail end of this casing at the 'bulkhead' I have chosen to leave it like this otherwise if you make the 'bulkhead fit, you have a large gap at the wheel bay and the cockpit tub sits too high. You need to trim off the bottom half of the 'bulkhead' as I have, if you take this route so that it fits inside the dorsal fuel tank. When fitting the cockpit tub, its a good idea to shim it up on a thin layer of blue tack before you super glue it in position, make sure the resin parts under the windscreen and behind the ejector seat are also a good fit before gluing, it takes quite a lot of dry fitting,
In order to make sure the model is not a tail sitter have packed some screws into blue tack and fitted it behind the ejector seat. Will have white metal undercarriages which will also help.
When glueing the fuselage halves, will be doing it in stages, travelling aft from the rear of the cockpit to the tail, then on the underside from the tail up to the yellow band, see photo B25, the last two photos show the miss match at the nose. Cheers Derek
[ATTACH]31037.IPB[/ATTACH]
[ATTACH]31038.IPB[/ATTACH]
[ATTACH]31039.IPB[/ATTACH]
[ATTACH]31040.IPB[/ATTACH]
[ATTACH]31041.IPB[/ATTACH]
[ATTACH]31042.IPB[/ATTACH]
[ATTACH]31043.IPB[/ATTACH]
[ATTACH]31044.IPB[/ATTACH]
[ATTACH]31045.IPB[/ATTACH]
[ATTACH]31046.IPB[/ATTACH]
