Hi peter, this is simply stunning work, your skill in scratchbuilding is fantastic. I really have a soft spot for the po2/u2 after reading up on the 'nachthexen' and making the old KP kit as one of their machines (see here http://www.scale-models.co.uk/aircraft-pictures/7651-polikarpov-po2.html), although i simply made the kit , unlike your superb scratchbuilt version! keep the pics coming, cheers tony
Thanks lads for your warm words. I hope not to disappoint you with the final effect. yak face I've seen your Po-2, and must admit you squeezed the most of it from that vintage kit
Thanks peter, coming from a master scratchbuilder like yourself thats made my day! cheers tony
Cheers lads! I've recently finished the tank and belly covers (which will be displayed aside finished model). Now as I have all the fuselage completed I could start painting. I decided to paint all the pieces separately still before assembly. It saved me a lot of masking and eased the painting process (in some cases I could paint “free hand”).
The wings are now fixed and rigged so I can show you how it went together. First I printed the wings outlines on adhesive paper and bandsaw the pieces out of 5mm polystyrene sheet.
Then I shaped the wings profile and gave the proper angle to the upper wing by cutting groves and inserting polystyrene wedges.
Next I could work on imitation of strengthening tapes. I did it by engraving lines and painting over with few layers of flat black.
I also had to modify the landing lamp. The one provided in PART PE fret gives wrong angle, so I replaced it with a piece of aluminum sheet trimmed to proper shape.
_____Bad:____________Good:_____
Then I could paint the wings and apply the decals.
