Seasons greetings all.
Here is my Trumpeter 1/32 Mig 17 cockpit tub. In the pix it looks a little simple and sparce, but in "real life" the small size makes it look Ok-ish.
I added some copper wire pipes and cables aswell as the port side cockpit light and rudder peddal straps.The PE harnass came from my spares box.
I tried something different on the pannel,Instead of dry brushing it I painted it black and wery lightly sanded the raised detal to give a very nice and crisp effect.
It will be painted in the collours of Mozambique Air Force MiG 17 #21 to depict the plane that Lt. Adreano Bomba defected to SA with.
Although a very nicely detailed kit ,the wing fences are miles to thick and will take allot of carefull sanding to thin them down.
Another thing I found to be a potential big problem is the fact that no airduckt is suplied, just the nose ring with splitter cone ,so any views from the front will be "wrong"
The front part of the canopy is also the worng shape when it comes to the framing and I really can't see any way of fixing that other than to get a correct one.
Theuns
[ATTACH]29878.IPB[/ATTACH]
[ATTACH]29879.IPB[/ATTACH]
[ATTACH]29880.IPB[/ATTACH]
Theuns
