Hi all,this ones not been moving that fast due to the cold weather (my sheds freezing!) but ive managed to get a bit done today. The filler on the wing joints has been sanded ,phew!, and the tailplanes are on but yet to be filled. The flaps have been scribed on the underside of the wing/fuselage, but thats about it for any external details- the actual craft was very smooth , being mainly plywood skinned , and devoid of panel lines/rivets etc. I have crash moulded a canopy as the airfix one was pretty thick and not very clear. I used the kit canopy to mould the new one from a piece of clear acetate (actually a piece of bubble bath bottle - deep heat!) by heating the acetate while clamped to a piece of MDF with a hole just bigger than the canopy ,and pushing the kit canopy through on a piece of dowel, then hold for a second or two till its cool and there we have a canopy . The shape and simplicity of this canopy made the job easy , if youve got a canopy with a return curve (ie. curves back in at the bottom) then you wont be able to use this method. Once its cut out and glued on it should be ok,although i might mask it up before fixing as it will be a bit delicate ,only having a very thin edge for the glue to fix. Heres the pics , hope this makes it a bit clearer (ha ha, clearer, yes? no? ok ill get me coat!!) cheers tony
[ATTACH]30929.IPB[/ATTACH]
[ATTACH]30930.IPB[/ATTACH]
[ATTACH]30931.IPB[/ATTACH]
[ATTACH]30932.IPB[/ATTACH]
[ATTACH]30933.IPB[/ATTACH]
[ATTACH]30934.IPB[/ATTACH]
[ATTACH]30935.IPB[/ATTACH]
[ATTACH]30936.IPB[/ATTACH]
