This is looking superb and, as Adrian has pointed out, the pre-shading is very tidy. I also like the care and attention put into the filling with masking tape being used to protect the surrounding areas. This cockpit is going to look amazing when the canopy is fitted.
Eduard Bf110G-4 1/48scale
Thanks Allyne,btw really like the video in your sig!
Adrian thanks I practiced a lot on some scraps before I trusted myself to attempt it.
Appreciate the kind words Richard,would a wash be in order over the top or should I leave it? I'm thinking the wash might be too much on top of the preshade just not sure?
Shes on her feet for the first timeComment
thanks Allyne and Steve really appreciate the input!!Thanks Basher and Kressy.
I took the advice given and mixed up some light dirt and black Promodeller wash with some ground burnt umber pastel for the first wash and hit the control surfaces and engine nacelle areas.
next after the wash dried I hit the cannon and exhaust stains with some thinned flat black followed by an overall coat of dullcoat.
I then ground up several earth tone pastels and dry brushed different pigments in high wear and prop blown dirt accumulation areasComment
I would go with a wash Trey. The preshading should give just that, a shading to the area of the joint but the wash is a very clearly defined line to show up the panel joint afterwards. The two techniques should complement each other. If you are unsure start with a lighter colour and very low opacity in a small area to see what you feel before committing to the whole model.Comment
Originally posted by \I would go with a wash Trey. The preshading should give just that, a shading to the area of the joint but the wash is a very clearly defined line to show up the panel joint afterwards. The two techniques should complement each other. If you are unsure start with a lighter colour and very low opacity in a small area to see what you feel before committing to the whole model.Comment
thanks Steve I thought I might have gone too heavy on the exhaust ,thanks Adrian
I had some misgivings about the diopole support ,the kit just has them flush glued to the nose. I know from past builds this would'nt be strong enough with all the tweaking required to get the antenae to line up. I know it might take away a bit from the appearance but this is my fix.
some stretched sprue was glued to the supports and then sanded as much as possible to blend it.
then painted,while the paint dried I marked off and drilled the mounting holes
hopefully this will do the trick ,just have them dry fitted for nowComment
