1/48 Scale - Supermarine Spitfire Mk.1
    cheers steve would the colours be the same as that ? like the colours around the dials etc ..?
    shane
    • colin m
      • 8741
      • Colin
      • Stafford, UK
      #32
      Great job. The pilot looks really good, a little like James May !!
      • flyjoe180
        • Jan 2012
        • 12390
        • Joe
        • Earth
        #33
        Good progress, everyone loves a Spitfire. Those documents regarding the undersides are very interesting.
        • stona
          • Jul 2008
          • 9889
          #34
          Originally posted by \
          cheers steve would the colours be the same as that ? like the colours around the dials etc ..?shane
          They would. The centre panel is the "blind flying panel" and self evidently holds the flight related instruments. To the right are the engine's instruments (temperature gauges,engine speed etc). To the right is a clock,brake pressure gauge and various positional indicators (for trim,U/C etc).
          Note that the control panel picture I posted has a different compass installation.A 1940 compass looked like this (I think it is missing a ring around the top but I'm not sure).
            Many thanks again steve
            Shane
              hey guys, quick update on what i been doing tonight, i have painted up the cockpit sides, attached the pilot to the seat, still need to connect his hand up to the controls, also i airbrushed the black panel and added some detail to the dials, im pretty happy with it, especially for my first model
              cheers guys
              shane
              [ATTACH]45682.vB[/ATTACH][ATTACH]45684.vB[/ATTACH][ATTACH]45683.vB[/ATTACH][ATTACH]45681.vB[/ATTACH]
              just to add, i have now fitted the instrument panel
              [ATTACH]45685.vB[/ATTACH][ATTACH]45686.vB[/ATTACH]
              [ATTACH]48754.IPB[/ATTACH]
              [ATTACH]48755.IPB[/ATTACH]
              [ATTACH]48756.IPB[/ATTACH]
              [ATTACH]48757.IPB[/ATTACH]
              [ATTACH]48758.IPB[/ATTACH]
              [ATTACH]48759.IPB[/ATTACH]
                fixed the cockpit inside and fixed the wings on.... quick question should i put the detail parts on i,e canopy, exhausts wheels etc etc .. spray the camo on then paint the detail part .. or how do you do it?
                cheers
                shane
                [ATTACH]45689.vB[/ATTACH]
                [ATTACH]48762.IPB[/ATTACH]
                  If you have a Android phone there's a free app i use all the time it's called "Hobby Colour Converter" it converts the big 4.
                  Tamiya, Revell, humbrol and Vallejo, Tap on the paint on the phone XF1 = Hum 33 = rev 36108 = Vall = 71057 .
                  It even gives you the RLM and RAL numbers.
                  Martin
                  • stona
                    • Jul 2008
                    • 9889
                    #39
                    I do mask and fit the canopy. You want it to blend in and not look added on. You need to not only mask the clear panels but,on a Spitfire,make sure no paint can get in under the centre,sliding section. A thin bead of Blu_tac,around the inside edges of that bit,will be your friend.
                    I tend to leave off exhausts,undercarriage,tail wheels and other fragile bits like pitot tubes as they have a bad habit of getting broken off. These I glue on before the final coat of varnish.
                    Antenna and IFF wires I do right at the end.
                      Thanks martin, I don't have a. Android phone but interesting to know,
                      Cheers steve, ill do that then, this is the link part Im not looking forward to, don't want to ruin it, oh and them great paint instructions that come with it state two different colour mixes for the lighter part of the camo, I'm guessing one is a typo :
                      The Centre sliding section, will be glued in place so no paint should leak under? Or am I not understanding correctly?
                      Shane
                        sorry for the short delay in post guys, i have just spent the weekend with the sealed knott at newstead abbey,
                        anywhere i have paint the camo and the underside, still got alittle tiding and touching up to to, colours are alittle be dark, but it will be ok for my first model.
                        shane
                        [ATTACH]46029.vB[/ATTACH][ATTACH]46030.vB[/ATTACH][ATTACH]46031.vB[/ATTACH]
                        [ATTACH]49082.IPB[/ATTACH]
                        [ATTACH]49083.IPB[/ATTACH]
                        [ATTACH]49084.IPB[/ATTACH]
                          Guys do I do any washes and weathering before I apply the gloss coat ,decals and matt coat or after? When do you do yours?
                          Shane
                            • 22770
                            #43
                            Hi Shane nice work so far. I apply my washes at the end ,so i paint then apply gloss/clear then decals then clear/gloss then washes then final matt if needed hope it helps but others may do it differently
                              Cheers ian, that's what I was thinking of doing, Cheers
                              • flyjoe180
                                • Jan 2012
                                • 12390
                                • Joe
                                • Earth
                                #45
                                I do it the same way as Ian. Your Spitfire is looking good Shane, very nice paint work.
