It has a mad amount of detail for 1/72 and is a hundred miles from old skool airf*x nonsense... Thick sprue gates and badly fitting LERX are the only gripes so far...
Looking good Stuart. I am a little behind you on a 1/48 Tamiya. Looking at that your detailing although a smaller scale looks far better than the Tamiya. The Tamiya have used raised panel lines etc which are as far as I am concerned impossible to replicate if you lose them in preparation work.
Mine is a Sea Harrier Falklands type. Which is yours ?
Thank you for the welcome back and the kind comments dudes, I promise not to be so long next time hahaha!
Laurie, I've seen the Sea Harrier kit that you're doing, it looks awful like the old airfix mould one too, but one has to hope it's better!!! This is the ban up to date Mark 9/9A from Afghanistan. There's even a special scheme for the last flight back to the UK, but I'm making this one ZD433(i think) affectionately known as Dirty Harry when it was displayed at the Yeovilton Navy Museum (although it's an RAF bird)
I envy you having that kit, I've been trying to find the cheaper revell repop but it's discontinued. that and the Trump 32nd are my holy grail models...
Ok dokey then (after thinking my compressor was fecked, turns out i was trying to top it up when it was already above the pressure switch cut off level) got light grey coat 1 and 2 on the wings....
