Airfix 1/48 Hawker Hurricane
  • Dave W
    • Jan 2011
    • 4713
    I've just started this after an eight month break from model making.I must say its good to be back at the work bench as I've really missed it.Got some great kits in my stash.But I've recently read four books by former Hurricane and Spitfire pilots and fancied a go at one of these.Ive made one before,in the eighties I think.But the cockpit isn't as well detailed as I remember.Not much of it can be seen anyway,so I will just add some Eduard pre-painted seat belts.Im going to build the 32 sqdn aircraft which requires a Rotol Propeller.The kit one looks a bit big,but I've got another from a more recent Airfix Spitfire kit.Not sure which one i will use yet.Ive just joined the IPMS and have asked for advice on there forum as well as on here.If I don't get an answer I will probably make both props up and go with the one which looks best.So far I've only put the cockpit together and painted it interior green (Humbrol 78).Im going to rescribe the raised detail on the wings and forward fuselage as I was pleased with the results when I did this to the Airfix Stuka.
  • yak face
    • Jun 2009
    • 13853
    • Tony
    Nice to see you back in the saddle dave! We all love a hurricane , a very characterful aircraft . looking forward to seeing this one , cheers tony
    • Dave W
      • Jan 2011
      • 4713
      Made a bit of progress.Fitted the Eduard seat belts.
      Ive also glued the wing and fuselage halves together.Then I made a start on the rescribing.Still got to sand off the raised detail.
      • colin m
        • 8770
        • Colin
        • Stafford, UK
        Looking nice Dave. I built the Italeri one recently, but have a bit of a soft spot for Airfix and so look forward to see this one develop.
        • mossiepilot
          • Jul 2011
          • 2272
          Welcome back to the fold Dave. A nice start on the Hurricane mate.
          Tony.
            • 22771
            Nice start Dave the rescribe looks good
              Nice start, looking good!!
              Polux
              • Dave W
                • Jan 2011
                • 4713
                Progress is slow with this one as I'm still doing work on my house.I didn't take enough care when fitting the wings to the fuselage.So a bit of filler is needed.The fit isn't as bad as it looks.I will sand it down this evening and do a bit more rescribing.Then I will tackle the tail plane joints.
                • flyjoe180
                  • Jan 2012
                  • 12433
                  • Joe
                  • Earth
                  Interesting to see this forming Dave. It seems to share a lot in common with the 72 kits. I'm glad the fit isn't as bad as it seems, it looks like there is a lot of putty on the joins.
                  • Dave W
                    • Jan 2011
                    • 4713
                    Thanks for the interest Joe.Theres a lot of putty on the joins because I put too much on!.Ive now sanded it down and put the second round of filler on.
                    The tail plane joins are not too good.So I've given them filler overkill.Ive also filled the top of the engine cowling where I slipped with the scribing tool!.
                    • Dave W
                      • Jan 2011
                      • 4713
                      Done some more sanding,scribing and polishing tonight.Finished off with round three of filler.Will rub it down tomorrow and finish the scribing.Then it needs a coat of primer to check if it needs anymore filler.
                        Nice fill job Dave,love the green putty!
                        • Dave W
                          • Jan 2011
                          • 4713
                          Not much progress due to most of my spare time being spent working on the house.I did manage to clumsily break the canopy though.
                          So I had to send off to Hannants for a vacform replacement which came as a pack of two.
                          I've cut one out and placed it on the model.Needs a bit more trimming but seems like it will be a good fit.
                          The kit doesn't have any landing lights for the leading edges of the wing.So I made some indentations in a piece of plasticine with the end of a paint brush.Then I filled them with two part epoxy.I've made several as its tricky getting two the same size. the two at the top of the picture should be about the right size.Just got to take them out of the mould and paint the back of them silver.I did this before when I built a Lysander and was satisfied with the result.
                          • Adrian "Marvel" Reynolds
                            • Apr 2012
                            • 3008
                            oh very nice tip with the landing lights, will store that one away. I tried using Krystal Clear a while back and mixing in clear orange for indicator lights, not very suscessful
                            Adrian
                              • 18271
                              The best way to do it with Krystal Klear is much the same as Dave did with the epoxy. Just put a few drops down on to a bit of wax paper or foil. They dry into a good lens shape, just flat on the back.
                              The Hurri is looking quite sharp Dave.
