Huma Modell 1/72 Junkers Ju EF 128
    another luft '46 kit
    what do you get for your £18-20?
    well theres a box
    a double sided sheet of instructions, construction on one side and paint suggestion on the other
    a small sheet of very basic decals
    i sprue of grey styrene parts with engraved detail
    and one canopy
    Construction starts as normal with the cockpit, very sparse, no detail on sidewalls and just a seat and joystick + pilot
    Theres a little more detail in the engine
    but one the body is fixed together all you can see of it is this
    not much need for filler apart from the wing roots which i filled with squadron putty then smoothed over with acetone to lessen any sanding needed.
    This is a pretty quick build with only 30 or so pieces making up the whole kit 6 of those are the engine.
    I decided to go a little away from the instructions and add a little "individuality" to the paint scheme
    but sticking with rlm colours for the camo, rlm 76 on the underside for instance
    hopefully get the topside started tonight.
    RLM 82 (Hu117) applied to upper surface tonight
      Oooooh thats nice Wayne love the 46 stuff,eagerly awaiting the next update keep up the great work!
        not much of an update but i dont want to rush this one. lol
        splinter camo done tonight, so touching up will be done tomorrow.
          Looks good with the yellow and red. Is a pretty cool looking plane.
          • mossiepilot
            • Jul 2011
            • 2272
            Thats a nice little kit Wayne, and you've done it justice.
            • colin m
              • 8755
              • Colin
              • Stafford, UK
              Nice one, I like the customised approach.
                all finished.
