V*RA the CANADIAN Flying Lanc' also known as VeRA to the 'locals'.
  • flyjoe180
    • Jan 2012
    • 12390
    • Joe
    • Earth
    #46
    Originally posted by \
    John did you hear about VeRA's emergency some months back ?One of the main wing tips folded up and she had to land! Some thought her time was up.
    A wing tip folded up? I hope they can repair it and get it airborne again soon.
    UPDATE:
    The Lanc has been grounded since April 17 when the lower bracket on the right wing tip came loose while on the first training flight of the season near Dunnville. The lose bracket caused the wing tip to point upward, forcing the crew declare an emergency and return to the John C. Munro-Hamilton International Airport where the heavy bomber landed safely.
    Following close inspection, museum officials determined a few nuts on the bracket had loosened slightly or the metal on the wing tip had become stretched over time causing the spacer-bolt assembly on the wing tip to fail.
    Mickeloff said the museum had new upper and lower brackets made for both wing tips.
    http://www.hamiltonnews.com/news/lancaster-back-in-the-sky-next-week/
    So she should be flying again by now?
      A wing tip folded up? So she should be flying again by now?
      Yes mate she is fully repaired now and has done several displays since then, When the BBMF heard about the wind tip
      folding up they checked out PA474 and renewed all the nuts on her as a precaution.
      When the incident happened it was all hush hush when it happened and even I was told to keep my trap shut.
      Roy Chadwick the designer of the Lanc' knew about the 'weak spot' on the Lanc' but he never did anything about it !
      Below is a picture of the underside of VeRA and if you look carefully you can
      still see the crumpling on the panel which was the result of the wing-tip folding up.
      Back to me model of VeRA............
      Filled in the two incorrect windows with plastic and a layer of super glue which will be sanded down level...Hopefully!
      Sanded the filled in windows and first coat of primer/black, fillering looks good at this point.
      Added undercarriage arm-locks which are the red rods!
      A few detail parts i've knocked out of plastic - bomb sight - bomb aimer seat - one aerial - and a grey thing which is under the nose of the Lanc'.
      Civil reg' added to the underside of the wing, not many people see this but its got to be one.
      Correct sized 100inch wing roundels and a note to any future Tamiya Lancaster maker!
      ''The wing roundels are too small and are actually for the Avro Manchester''
      My modded rear inflatable Dunlop tyre, The twin shimmy tyre was cut and and scrapped.
      Thanks for having a read and nebbing over the pictures.
      Ian.
        ** If anyone is going to build this kit I would tell them NOT to paint the front turret
        as Tamiya say but alter the framework and Tamiya have got it wrong**
        • flyjoe180
          • Jan 2012
          • 12390
          • Joe
          • Earth
          #49
          Amazing detail here Ian, and thanks for the follow up on the wingtip.
            • 22770
            #50
            Some amazing work Ian just amazing
            • colin m
              • 8741
              • Colin
              • Stafford, UK
              #51
              The build looks amazing, great work here. So, how big will the beast be when built, I fancy building something big !
                Hi Colin.
                The Tamiya Lancaster is a bit of a whopper and measures 25.5 inch's wing-tip to wing-tip and 17 inch's the entire fuselage length.
                Its finished now and can be viewed via' the below link in the forum...
                http://www.scale-models.co.uk/planes/17234-tamiya-1-48th-avro-lancaster-canadian-warplane-heritige-vra.html#post143599
                Cheers.
                Ian.
