This is my next project.It contains a lot of resin parts.Something I don't have much experience with.I haven't bothered with sprue shots as they look much like most other kits.
The kit also contains a nice little PE fret.The instrument panel consists of a piece of film that you stick to a plastic panel .Then the etched panel is stuck over the top.The instruments on the film are not very visible. So I put some decals from an after market instrument decal sheet over the top of them.
Then I added the resin throttle stand and PE levers.I found working with such tiny parts quite challenging.But they should look ok through the canopy.
Next I glued some of the resin parts to the cockpit floor.Not as easy as it sounds.Although I washed the resin parts in detergent before I started the build,I still had a lot of trouble sticking them together.I used Rocket CA to fix the framework to the radio operators table and it bonded instantly.But it wouldn't glue this assembly to the cockpit!. neither would Loctite CA .I ended up using two part epoxy. I saw some amazing builds at Telford.Some really amazing fine detail.God knows how they do it. I'm still a million miles away from that standard.
ลต
ลต
