Yes they are good.Ive spent many hours with rolls of Tamiya masking tape and a scalpel masking canopies.This product makes the job so much easier.Well worth £5.80 for a set.I will definately buy them again when I get round to doing my Tamiya 1/48 Lancaster and Italeri Avenger.Both kits have a lot of glazing to mask.
Classic Airframes 1/48 Avro Anson
I've started to paint the Anson.Primer coat is on and then the aluminium colour on the underside.
I sprayed the Vallejo Aluminium last night.But it's still not dry enough to mask 24 hours later.This time of year it's too cold and damp in the shed for it to dry properly.Thats the only problem I find with these acrylics.So I've put the model in the bedroom to dry properly.So tonight I've just masked the gun turret.
I should have used enamels really.But I've got his big bottle of Vallejo primer I wanted to try out.This builds dragging a bit now.I need to crack on and get it finished.Im worried about messing it up again though.Comment
Nice looking NMF Dave. The one good thing about painting in the cold is it does tend to flow or 'level ' better .Comment
Just got caught up with this and you've done a great job so far. This is going to be something to be proud of when it's done.
Tony.Comment
Originally posted by \.This time of year it's too cold and damp in the shed for it to dry properly.Thats the only problem I find with these acrylics.So I've put the model in the bedroom to dry properly.
This is the sophisticated Halfords Plastic Primer curing system I'm utilising to ensure that I can press on with my Natter tomorrow.
I'm not sure that I'll convince SWMBO to leave the heating on overnight
SteveComment
Neat idea Steve.Mind you,if you get it too close to the radiator you will end up with a swept wing Natter!.Thanks Ole and Tony.I seem to be going through a bad patch with my modelling at the moment.Just spent half an hour turning my shed upside down looking for one of the props!.Eventually found it in the corner fold of the kit box lid.Then I decided to spray Vallejo gloss clear over the now dry aluminium.The idea was to make it less likely to come off when masked.And also to give a smooth surface for the under wing decals.For some reason I ended up with white blobs all over the underside!.So I set to with a cloth and some IPA and cleaned it off.This of course removed most of the aluminium and a bit of the primer.This build is fighting me all the way.But the problems are almost all of my own making.Occasionally things I normally have no problem doing with my modelling just seem to go wrong.I will finish it though. It won't beat me!.Comment
I know the feeling Dave the NMF on the P-47 fought me the whole way,keep at it I know it wo'nt beat you!Comment
That's a real shame Dave the aluminium was looking really good. I had a similar experience with my Wildcat I thought I was being clever when I put a coat of klear on it, it made the finish go a little dull plus when I masked it it just pulled the paint off. So that's when I decided to put the colour down first. I hope you manage to sort things out.
VaughanComment
