Very interesting building report Vaughan. Will follow him interested. Good luck continues.:xyxthumbs:
Hasegawa 1/32 P47D Republic Thunderbolt
Thanks Stefan,
This afternoon I bit the bullet and masked off the invasion stripes and got down to spraying the aluminium. This a new bottle so things should be ok. It sprayed on ok but I don't seem to be able to achieve a really shiny reflective surface, yet when I spray smaller objects like drop tanks tail wheel bay doors I can geta good lustre. Oh well the paints down and the masking is off. The engine, undercarriage and flaps are a dry fit but it gives you an idea what she looks like. Now I've got to allow the aluminium to go off before I start to decal her up, the quandary is do I put a coat of Klear on first which will dull the finish or risk not using it at all. But on the other hand I will need to seal it somehow so that I can apply a wash to enhance the panel lines. Any suggestions?
[ATTACH]61250.IPB[/ATTACH]
[ATTACH]61251.IPB[/ATTACH]
[ATTACH]61252.IPB[/ATTACH]
[ATTACH]61253.IPB[/ATTACH]
[ATTACH]61254.IPB[/ATTACH]
[ATTACH]61255.IPB[/ATTACH]
Nice recovery on the NMF Vaughan! I use a Urethane clear over my NMF ,have also used testors KlearKote with some success. Looking forward to the next updateComment
Hi Vaughan
You gotta polish it bro she shinier the base coat th!e shiny the alclad and clear doesn't bother it
I watched a demo on youtube they used clear on top of the under coat then prayed a lot of clear. When dry polished it right up then put the alclad over nice and slow misting them when that's dry it should be shiny you can buff it up with a micro cloth then clear again for your decals and weatheringComment
That's one crazy post Martin but I get what you mean. I'm using Vallejo paints so I don't think that it would work for me, thanks for the idea anyway.
I did find some photos of a P47D that shows the aluminium can be quite dull so I shouldn't be too hard on myself regarding the finish. I finished off the canopy this morning having masked and spraying it last night followed by some Klear and a wash to enhance the rivet detail. Anyway lots still to do, will post some more progress soon.
[ATTACH]61299.IPB[/ATTACH]
[ATTACH]61300.IPB[/ATTACH]
[ATTACH]61301.IPB[/ATTACH]
[ATTACH]61302.IPB[/ATTACH]
[ATTACH]61303.IPB[/ATTACH]
I think you've answered your own question regarding the dullness of an aluminium finish on service aircraft.
It's almost impossible,in a B+W photograph,to tell whether the underside of an aircraft is natural metal or neutral grey. There's a clue there
SteveComment
I really think that too many silover aircraft look far too shiny so yours to me is perfect. The washes around the nose are spot on and that canopy frame looks superb. When you compare that with the rivet detailing on the real aircraft you can see how close you are with it.
Fantastic job looking really good.Comment
Hi All
Progress has been going on in the back ground over the last few days, unfortunately no photos to show my progress. So here's where I'm up to. Decals are all down, some needing needing quite a lot of Decalsoft. The real tricky ones were around the intercooler vents which is where the Stars and Bars are situated. All the decals have been sealed and a wash has been applied to enhance the panel lines. Wing tip navigation lights are fitted with Clearfix. Blast tubes(which required drilling the barrels out) and pitot tube have also been fitted. All that remains is the gunsight and aerial wire. I have added my own fuselage ceramic insulator point as it is just a flat circle. Photos will follow of the finished Jug in the Aircraft Pictures Section. Thanks to everyone( too many names to mention) who have followed this Thread and given me help, encouragement and info along the way.Comment
