1:32 Revell Hurricane IIC - 5 sqn, 1943-44
    Having completed the 5 Sqn Curtis Mohawk, its done the job and whetted my appetite for the rest of the "Planes my Fatehr Fixed" project. So to that end, lets have a go at one of the main aircraft he worked on - the Hurricane IIC that was the replacement for the Mohawk for 5 Sqn in India and Burma.
    Some history: 5 Sqn had been based in the far east at the outbreak of WWII and when Japan joined the war, the Sqn were moved to Calcutta in an air defence role flying Audaxes, but these were inadequete so they were replaced with the Curtiss Mohawks, which were to provide air defence and bomber escort duties for attack in northern Burma.
    Eventually in mid 1943, the Mohawks were replaced with a mix of HUrricane IIC and IID. My father was transferred from 81 Sqn to 5 Sqn in November 43 and spent Christmas in Sapam, 50 miles from the border with Burma and coincidentally just down the road from the recently relocated 81 Sqn - they invited my father for Xmas dinner and I still have the menu which my dad had got his old comrades to sign. Spam was an ideal position to launch ground attacke raids into the Japanese positions along the Chindwin Rover.
    So for this build I will be using this kit which I was lucky enough to pick up at the Telford Kitswap as the basis:
    Its not a terribly complex kit - its major downfall being that it has raised panel lines. I'm not sure I'm yet up to the task of rescribing... maybe this will be the time to try it out! Ther eis a lot of rivet detail that I'm loath to ruin though:
    so I'm in a bit of a quandry about this - any suggestions?
    So to improve the build itself, I invested heavily in aftermarket gear at Telford, picking up several items from Grey Matter Figures such as the cockpit and wheelbay enhancements. here is all the aftermarket stuff I aim to be using:
    Moving in a clockwise direction: on the black page you can see the cockpit set in the top left and the wheelbays in the bottom right. Next to that is a set of decals for the lettering in the right colours and size for 5 Sqn in India. Below that is a vacform canopy and next is a set of replacement exhausts, then replacement cannons and finally some masks for the canopy.
    Of course this is the build that I want to make diorama out of, featuring my dad doing his job as an electrician. So here are the final extras that will be used to create the diorama. In the family photo album, we've got several pictures of my dad from this period and in all of them he's wearing a bush hat, open shirt and shorts. So to get that combination I've got this little lot:
    Clockwise from the left: Airfix 8th Ary Multipose figures - this will be useful for the lower body, Airfix 1-32 Australian infantry - this will be great for the bush hat and open shirt torso. Next is the 1:32 Aber hand tools set - you'll have seen the 1:48 version of this in my Mohawk build, I suspect that this set will be easier to put together - not so eye-straining! Finally, I will toss in the 1:32 resin accumulator trolly from Iconair. Now I think this will need to have a compressor motor scratch built on the top, but lets cross that bridge when we come to it!
    So let us begin with the build. One of the first things I noticed was the elevators are cast as one complete piece. Well thats no good if I'm build a parked up machine undergoing maintenance! So I assembled them and then the razor saw came out and they were cut up. The notch that exposes the hinge was cut in and some plastic rod added. Two brackets were also added in the appropriate places to provide the attachment points for later.
    I also started opening up the fuselage to expose the electrics that my dad would have been working on:
    which also shows the elevators in an earlier stage of construction. Since the plastic of the fuselage is quite thick I chamfered the edges to thin the visible skin:
    I've been researching the internal layout of the fuselage so I can scratch build what will be visible behind these panels. Follow this link to the IWM collections to see the sort of thing I will be aiming to achieve, although not with the wellies! I'm still doing the research to get the internals as correct as possible - I'll start building the cockpit next as this will provide the basics from which I can build further back into the fuselage to provide the framework for the electrics I will be displaying.
  • stona
    • Jul 2008
    • 9889
    That's a great start to an ambitious project.
    There's not much you can do with that raised detail unless you are prepared to rescribe. I built one of these Revell kits as a MkI years ago and just sanded back the detail a bit and rescribed the correct panels for the machine guns.
    • mossiepilot
      • Jul 2011
      • 2272
      A nice start Andrew. Looking forward to seeing more.
      Tony.
        looking forward to seeing this unfold,the pic you are using is awesome
        mobear
        • colin m
          • 8801
          • Colin
          • Stafford, UK
          Raised panel lines. Well I haven't tried this, but it sounds possible. The trick I read was to spray the raised lines black. Then after applying the colours very gently sand down on the panel lines and the black will start to show through.
            Thanks for the suggestion colin. Sorry I've been a bit quite on the updates front for a few days, but I thought I'd take the opportunity tonight to post an update. So after thinking about it for a while I did decide to sand down the raised panel lines, especially after realising that this wing is just the "A" wing with the cannon nozzles and a couple of blisters added. The panel lines still represent the opening for the 4 machine guns on each wing. So the sanding started...
            The I decided it was time to look at the undercarriage bay, since I had bought the Grey Matter upgrade. So to this end, the razor saw came out and large rectangular hole was cut into the bottom wing. This was a tricky job and I had to use dymo tape to make sure I kept the right shape. The the resin assembly began.
            Let me warn you that although these Grey market updates are beautifully cast and fully of lovely detail, the instructions are really difficult to use. They consist of a couple of pages of A4 which have colour photos printed on with an inkjet printer. The print quality is pretty poor and its almost impossible to read some of the labels on the photos. I emails Grey Matter asking if there were electronic versions - in fact the instructions at one point even say look at their website for more detailed photos, but I couldn't find them anywhere. Its a real shame because these upgrade sets for both undercarriage and cockpit are superb otherwise. I've order the other update set which will update the nose to a proper Mk II with the proper spinner as well - waiting for that to arrive shortly I hope!
            Anyway, sadly I forgot to take photos during assembly but here is waht is looks like after its been installed back in the hole cut in the lower wing:
            The kit legs are used and attach to the white plastic rods you can see at either extremity. I've got a slight problem with the secondary leg bay as this is one of the areas where the instructions are not very clear. I've got some reference photos of the real thing however so I will be sorting this out. I've used thin copper wire to represent various air hoses and pipes. This will all come up lovely I reckon once its been painted - pity it will be barely visible
            So back to the cockpit then. As you saw int he earlier updates, I've cut the panels open under the cockpit just behind the seat. This is where a lot of the electrics are housed and would be where my dad would have worked a lot of the time. First things was to build the cockpit update and then extend the tubular fuselage frame back from it to represent what would be visible in the open panels...
            I've yet to add the seat and the instrument panel and upper part of the control stick. There are also a few extra levers and bits and bobs to also add. As for the framework, I need to install a horizontal shelf in the first inverted triangular segment of the frame, plus start looking at putting the extra details in such as control wires, pipes and so on...
            There we go some progress, but lots more to come...
              really really good,love the way you`re going all out on this,and does it look good?yup sure do,and its the 21st and i`m still here lol
              mobear
                Good start so far
                • stona
                  • Jul 2008
                  • 9889
                  Originally posted by \
                  its the 21st and i`m still here lolmobear
                  There's still time
                  Nice job getting the wheel wells in. Does the upper wing still fit okay? I've had to do a bit of thinning fitting a similar resin set into the PCM Hurricane.
                  • yak face
                    • Jun 2009
                    • 13870
                    • Tony
                    Great work andrew , keep the pics coming , cheers tony
                      Thanks tony, steve, ole and Plastikbasker! Your wish is my command so here is another update...
                      Last we saw how I'd extended the frame from the back of the cockpit. So how does this look INSIDE the fuselage?
                      The observant amongst you will also notice I've added the shelf that some of the equpment will sit on. What this test fit showed is that I need to extend the frame another segment back to that you get the impression it is continuous down the inside. But what about the interior fittings I hear you ask? Ahh well a start has been made:
                      I found some useful photos on a thread about a 1:24 Hurricane build on "another forum whose name starts with B" which shows the components in this space:
                      so the above tiny build is representing the component in the lower centre of the first picture, which sits on the left hand side of the lower framework. It will have some wires added to it to conenct to the other components.
                      I then got somewhat distracted when yesterday the postman delivered the Hurricane IIC update set from Grey Matter Figures! Woot! This set contains the following:
                      and of course most important, an updated nose:
                      Now to fit this nose takes some quite drastic surgery to the main fuselage, so I finally joined the two fuselage sides together and when the glue was dry got the dymo take and razor saw out...
                      Test fit:
                      Knowing where to cut was tricky - Grey Matter provide diagrams, but converting a 2D picture onto a 3D model is tricky. Never mind, any gaps are always fillable eh?
                      I seem to have cut and replaced an awful lot of plastic off this model!
                      So filling some of the gaps with some plastic shims, I got it fitting as well as I could:
                      The new nose also required chopping off a chunk of the front of the wing assembly:
                      and it was only when test fitting the wing that I discovered that there is a large mismatch between the wing joint in the resin nose and the shape of the wing itself. It might have partly been my fitting to the fuselage but it was generally higher up than the wing so various fixes had to be applied and you can see in the above photo the addition of another plastic strip to bridge a gap I created by cutting too much plastic away! This cut was almost impossible to judge accurately due to the complex curves in this area. In the end I've got it to fit but it did take some careful reshaping of some areas, which will almost certainly compromise the accuracy of the profile in this area. Ah well, can't have everything I guess - the profile is MORE accurate with this Mk II nose than the original kit so we are closer than before.
                      During this I did attach the upper wings to the lower section. I painted the inside where it might be seen through the cannon shell ejection slots NATO black. My next task is just settling the seams down as the fit isn't very good. Same with the fuselage.
                      As for the rescribing - the decision has been made for me - so much sanding has been required already that the original surface detail is rapidly disappearing or has vanished already. The Grey Matter Figures set does come with a good panel line illustration on the wings which I will use along with other sources as a rescribing guide. The fuselage doesn't change all that much and the resin nose has good inscribed detail already.
                      I have to give my thanks to Mark at Grey Matter Figures for getting this set out to me so quickly, especially since they are having issues with their online shopping cart so this all had to be handled manually!
                      Oh and finally a piece of good news - I finally took a closer look at the propeller that comes with the kit and it turns out to be a Rotol prop! About time I got a break on this build
                        you know what the bits you are replacing seem to make it alot smarter mate,i have a 1/24 mk1a spit,and now you have given me food for thought
                        mobear
                        • yak face
                          • Jun 2009
                          • 13870
                          • Tony
                          Top surgery Dr andrew , its certainly going to look like a mkII when youve done . The resin bits look good too , nicely detailed . cheers tony
                          • stona
                            • Jul 2008
                            • 9889
                            It looks like you are doing well with that! It's incredible how what seems like a few simple upgrades can snowball into such a major project that you hardly have any of the original kit left.
                              Went into the office today and was one of only 3 people there. Come lunchtime they left as well so I put in one more hour and came home! This afternoon then saw some building with teeny tiny pieces of plastic card, rod and spare bits of PE fret to continue with the internal components:
                              Still a couple more boxes to build that go on the right side of the shelf.
                              In the meantime, the wings and fuselage has had a load of filler liberally applied and sanded down, then I put some primer on and repeated the process. Wing is now drying from the latest round of primer and the filler should have dried on the second round of the fuselage. All in all the joints are remarkably smooth! The primer on the wings showed up some residual panel lines, particularly the machine gun panels, so they got sanded down a bit further.
                              Then I went through my reference books again, bookmarking all the useful photos. I've got the following in my "Hurricane" library: Squadron/Signla Publications Hurricane Walkaround, Hawker Hurricane Inside and Out by Melvyn Hiscock, Haynes Hawker Hurricane Owners Workshop Manual, Hawker Hurricane by Peter Jacobs (Crowood Aviation Series) and finally The Hurricane II Manual from the RAF Museum series. This last one is a collection of the actual technical manuals that would have been used by the ground crew and it really feels like I've got a connection to my Dad back in 1944 as I am sure he would have been looking at the same circuit diagrams and schematics as I am looking at in this book!
                              So thats all before the Xmas break, got family and other commitments for the next couple of days so its likely to be Thursday before I get a chance to return to the modelling table...
                              Merry Christmas everyone!
