F-22A Raptor - 1:72 Academy
    Not wishing to tread on Ljubo's (aka Pilot Program) toes it just happened that this was my next scheduled build. Ljubo as you know is doing the 1:48 Academy build in remarkable detail I must add, so I don't plan to do a step by step unless someone is particularly interested. I have shown photos of the kit below, and I intend going for the elusive Raptor sheen using Gunze (Mr Hobby) paints including their super metallics which I have never used before. The kit comes in 3 off grey plastic sprues plus two off clear plastic sprues (one tinted and one clear). The only extras I will use is my usual Eduard Zoom set to enhance the cockpit. At the moment I don't think I will fit the weapons provided with the kit. Cheers Derek
    [ATTACH]58533.vB[/ATTACH][ATTACH]58534.vB[/ATTACH][ATTACH]58535.vB[/ATTACH][ATTACH]58536.vB[/ATTACH][ATTACH]58537.vB[/ATTACH][ATTACH]58538.vB[/ATTACH][ATTACH]58539.vB[/ATTACH][ATTACH]58540.vB[/ATTACH][ATTACH]58541.vB[/ATTACH]
    [ATTACH]60395.IPB[/ATTACH]
    [ATTACH]60396.IPB[/ATTACH]
    [ATTACH]60397.IPB[/ATTACH]
    [ATTACH]60398.IPB[/ATTACH]
    [ATTACH]60399.IPB[/ATTACH]
    [ATTACH]60400.IPB[/ATTACH]
    [ATTACH]60401.IPB[/ATTACH]
    [ATTACH]60402.IPB[/ATTACH]
    [ATTACH]60403.IPB[/ATTACH]
    Whilst 'Pilot Program' is having a break from his 1:48 Raptor, I thought I would share a few shots of my progress with my 1:72. The fit is generally good with the exception of the intakes which are a real pain, one of the worst I have had to deal with. Tons of filing/shaving/sanding and dry fitting. There is a lot of ejection pin holes in awkward places also.
    [ATTACH]59980.vB[/ATTACH][ATTACH]59981.vB[/ATTACH][ATTACH]59982.vB[/ATTACH][ATTACH]59991.vB[/ATTACH][ATTACH]59983.vB[/ATTACH][ATTACH]59984.vB[/ATTACH][ATTACH]59985.vB[/ATTACH][ATTACH]59986.vB[/ATTACH][ATTACH]59987.vB[/ATTACH][ATTACH]59988.vB[/ATTACH][ATTACH]59989.vB[/ATTACH]
    As you can see above the model has been primed with my usual Tamiya white aerosol. I am trying to achiev the 'Raptor Sheen' finish as the photos below.
    [ATTACH]59979.vB[/ATTACH][ATTACH]59990.vB[/ATTACH]
    I have freehanded the edges of the kit with a 50/50 mix of Mr Hobby H314 and H334 this morning so will give it 48 Hrs to cure before I mask it off.
    [ATTACH]59992.vB[/ATTACH][ATTACH]59993.vB[/ATTACH]
    Cheers Derek
    [ATTACH]61725.IPB[/ATTACH]
    [ATTACH]61726.IPB[/ATTACH]
    [ATTACH]61727.IPB[/ATTACH]
    [ATTACH]61728.IPB[/ATTACH]
    [ATTACH]61729.IPB[/ATTACH]
    [ATTACH]61730.IPB[/ATTACH]
    [ATTACH]61731.IPB[/ATTACH]
    [ATTACH]61732.IPB[/ATTACH]
    [ATTACH]61733.IPB[/ATTACH]
    [ATTACH]61734.IPB[/ATTACH]
    [ATTACH]61735.IPB[/ATTACH]
    [ATTACH]61736.IPB[/ATTACH]
    [ATTACH]61737.IPB[/ATTACH]
    [ATTACH]61738.IPB[/ATTACH]
    [ATTACH]61739.IPB[/ATTACH]
      Looks fantastic
        After 8 solid hours of masking on this little blighter got the lighter metallic finish on. This is a 50/50 mix of Mr Hobby (Gunze) H315 + SM04 diluted with approx. 50% Mr Color Thinner. Waiting another 48Hrs to cure (touch dries in minutes) before masking again for the darker metallic finish. Cheers Derek
        [ATTACH]60138.vB[/ATTACH][ATTACH]60139.vB[/ATTACH][ATTACH]60141.vB[/ATTACH][ATTACH]60140.vB[/ATTACH]
        [ATTACH]61879.IPB[/ATTACH]
        [ATTACH]61880.IPB[/ATTACH]
        [ATTACH]61881.IPB[/ATTACH]
        [ATTACH]61882.IPB[/ATTACH]
        • colin m
          • 8741
          • Colin
          • Stafford, UK
          Looking nice Derek. The metallic looks like it has nice 'fine' particals in it. Some metallics can be quite out of scale.
            • 22770
            Looking very good Derek great work so far
            • flyjoe180
              • Jan 2012
              • 12400
              • Joe
              • Earth
              Nice work Derek.
                Great a/b work Derek ca'nt wait to see it unmasked!
                  Thanks Gents, you're a mind reader Trey just took the masking off.
                  Had a long hard think about putting on the darker metallic colour, finally decided to do it free hand, which scared me as I have never done it on a 1:72. Anyway I changed the needle in my Iwata Revolution CR to a 0.3mm needle. I used a 50/50 mix of Mr Hobby (Gunze) H317 + SM03 diluted with approx. 20% Mr Color Thinner.
                  Here is the result.
                  [ATTACH]60323.vB[/ATTACH][ATTACH]60324.vB[/ATTACH]
                  Removed the masking from the leading edges and the wheel bays; still a good bit of work in finishing off the cockpit/ under carriages/ wheel bays/ exhaust petals/decals.
                  Cheers Derek
                  [ATTACH]61940.IPB[/ATTACH]
                  [ATTACH]61941.IPB[/ATTACH]
