This is my latest build. It may not turn out 100% accurate, as I am using the colours I currently have, My main aim is to enjoy building though:
1/72 Airfix Spitfire Mk1a
GuestTags: None
Interesting. I am doing the same kit although I have got only to the assembly and gluing stage. I have been practicing airbrushing but having got that more or less sorted I will be making progress on the kit. I will follow your progress.
I had trouble fitting the cockpit bits in — they seemed too long for the space provided by the slots on the inside of the cockpit, but that was probably due to my lack of experience.
I haven't yet removed all visual traces of the top front fuselage seam. Mr. Dissolved Putty will be my next step. Then the canopy. -
Looking good Mpal.im building the Airfix 1/48 version at the moment.This kit looks like a scaled down version.The build up of the cockpit looks exactly the same.Your colours look good to me.Brown looks very similar to the Vallejo dark earth I use.And the Sky underside colour looks right to me.I see your using Revell Acrylics?.I used one of them for the first time On a mk9 spitfire Ive just finished.Apart from the odd pot they come in I'm pleased with the finish they give.The paint is quite thick so will go a long way.I thinned it with tap water and it sprayed on really well with my airbrush.Will definately be getting some more.Comment
thanks guys. I thin the revell acrylics with water too. The underside is Tamiya, which is awful to brush paint.Comment
Well, started the camo now.
Its all freehand brushpainted, following the painting instructions as a rough guideComment
Thanks Dave. My painting skills arent up to the standard needed to pull off large scale models.
Although my excuse that room for storage means that smaller models are the only option for me, saves me from too much explanation to SWMBO.Comment
Nice looking Spitfire there.
I've struggled to brush paint with Revell, and have found Vallejo Model Colour much easier to work with.Comment
Originally posted by \Nice looking Spitfire there.I've struggled to brush paint with Revell, and have found Vallejo Model Colour much easier to work with.
Cant say I have any issues using Revell Aqua Colour at all.
I thin with tap water, and sometimes some Windsor and Newton Flow improver added (a drop). Brush painting Tamiya on the other hand!!Comment
Painted the gun areas red, and did some slight touching up.
Hope to get this clear coated tonight, ready for decals tomorrow.Comment
I almost forgot about the exhausts and the antenna.
SO these are now fitted. Exhausts were painted using Tamiya Flat Aluminium, with a wash of Revell Aquacolour Anthracite over that. I think it gives a very good effect.Comment
