Mossy TR33
    Some nice chopping and shaping there Ian.
    I take it the resin sticks to the plastic with normal adhesives, or is there a specialist one for the job?
      • 18272
      Thanks Colin. I normally use CA/super-glue call it what you will. You can also use epoxy but I find it messy (and slow) to work with.
      Off to find some pictures of flaps. (that just reads so wrong. o.O )
        Right, so superglue does the job .. That's reduced my hesitence in getting any kits with resin parts, I just imagined having to get new glues etc . thanks for the info.
        Originally posted by \
        Off to find some pictures of flaps. (that just reads so wrong. o_O )
        I'm not even going to ask .... Whatever floats your boat
          • 18272
          Right, so superglue does the job .. That's reduced my hesitance in getting any kits with resin parts, I just imagined having to get new glues etc . thanks for the info.I'm not even going to ask .... Whatever floats your boat
          Erm its not a boat, its an aeroplane... Could not find any parked with wings up and flaps down, so I don't think I'll bother. But I did get a good look at the profile of them.
            That's a shame, would be an unusual build if you could manage it.
              • 18272
              So late last night I started to prime a few bits and today I started to paint said bits...
              Got the Nacelles fitted which in true Tamiya form was perfect. Due to the way the kit is designed, I found that I could carry on while waiting for the seats, so I did. The front section is only dry fitted and can be taken off again to put the rest of the cockpit in then glue it up.
              There is a decal for the dials on the IP but haven't looked at that yet..
              [ATTACH]69420.IPB[/ATTACH]
              [ATTACH]69421.IPB[/ATTACH]
              [ATTACH]69422.IPB[/ATTACH]
              [ATTACH]69423.IPB[/ATTACH]
              The "thimble" radar nose is on and a fitted perfectly in the hole! Small bits painted; legs, wheels and exhausts, So the next frightening bit will be cutting out the vac formed canopy and getting all those frames painted. Oh Joy.
              [ATTACH]69424.IPB[/ATTACH]
              [ATTACH]69425.IPB[/ATTACH]
              [ATTACH]69426.IPB[/ATTACH]
              [ATTACH]69427.IPB[/ATTACH]
              Oh well back to it.
                Looking top notch Ianm loving it.
                  That does look good mate
                    • 18272
                    An experiment. I have as I mentioned a Vac formed canopy for this and there was only the one in the box...It needs to be done right first time.
                    I put the tamiya decals on the inside of the canopy and thought they looked a bit naff...I also had another thought.
                    [ATTACH]69511.IPB[/ATTACH]
                    Take a bit of clear decal paper and paint it Interior green and leave to dry
                    then paint it the exterior when that has had a day to dry, cut thin strips off with a sharp blade.
                    [ATTACH]69512.IPB[/ATTACH]
                    Place the "decals" on the frames for the cockpit....
                    [ATTACH]69513.IPB[/ATTACH]
                    Not finished yet but it looks OK. Or does it...?
                    The best of it is if it goes wrong I can wash them off again with out leaving any marks.
                    I have also done a patch in red for those keep off crosses on the oil coolers. Always a pain in the...
                    • Dave W
                      • Jan 2011
                      • 4713
                      #25
                      Looking good Ian.Ive got the mkiv in my stash.Looks like a superb kit in true Tamiya style.
                        Coming along well Ian
                        • flyjoe180
                          • Jan 2012
                          • 12463
                          • Joe
                          • Earth
                          #27
                          Your canopy looks good Ian, interesting method and very effective I think.
                          • Dave W
                            • Jan 2011
                            • 4713
                            #28
                            Last time I tried painting clear decal the paint flaked off when I put the decal in water.I painted it with enamel.Havent tried it with acrylic paint.Is that what you use?.
                              • 18272
                              Last time I tried painting clear decal the paint flaked off when I put the decal in water.I painted it with enamel. Havent tried it with acrylic paint.Is that what you use?.
                              Yes I use Vallejo model color. I just gave it a couple of light coats, then a wet coat and left it over night to dry. I removed the kit's canopy decals and will do them again with my own.
                              I wish I could say that it was my own idea, but I read it on the www someplace.
                                • 18272
                                An update!
                                Well I got some paint on it. The decal for the instrument panel was in a nut shell, naff, so that got painted as well.
                                [ATTACH]69577.IPB[/ATTACH]
                                The post shading on the EDSG just shows through and on the Sky shows quite well.
                                [ATTACH]69575.IPB[/ATTACH]
                                [ATTACH]69576.IPB[/ATTACH]
                                [ATTACH]69578.IPB[/ATTACH]
                                [ATTACH]69579.IPB[/ATTACH]
                                [ATTACH]69580.IPB[/ATTACH]
                                [ATTACH]69581.IPB[/ATTACH]
                                The main wing and nose are only dry fitted pt. Still waiting for the seats to turn up so I still can't button it yet!
                                The canopy...I think it worked out OK. It actually looks like frames!! You can see the colour difference better over the dark back ground. All I have to do now is cut the s*dding thing out. Hate that bit. (the very bottom frame will be painted on after the canopy is glued on.
                                [ATTACH]69582.IPB[/ATTACH]
                                [ATTACH]69583.IPB[/ATTACH]
                                I made some decals yesterday, but they are only the black under-wing codes.
                                More about that later.
