I have attached the upper wings to the fuselage/wheel well assembly. On a Tamiya Spitfire this would take ten minutes, it's taken me well over three hours to get this how I want it!
I had to remodel the wing slightly to get everything in the correct position (as you'll see further down).
This is the worse side with a bit of filler in.
Have a look at the underside now.
You can see that the outer section of the lower wing has to butt up to the centre section. If you get the upper wing even a fraction out of line that join, running from front to back across the wing, is going to need a lot of sorting. I saw another build of this kit where the modeller had obviously had to fix this. He did a great job, but was probably a victim of following the instructions
You have to plan ahead, particularly with a limited production kit where things will fit, but not necessarily fall into place. Throughout all the numerous dry fits (as I adjusted the upper wing/fuselage join) I included this outer lower section of the wings.
Dry fitted below you can see there is a nice straight join which won't need a lot of remedial work.
There you have evidence for today's tip of the day. Try to plan at least one or two steps ahead. It will prevent you suddenly having something bite you in the ar*e when it is either too late or very difficult to fix!
The actual construction of the major parts is quite quick. There are no niceties like separate control surface (except for the rudder). As a result the main aeroplane is built and primed. I've spent more time cleaning up the parts than sticking them together. There is a lot of flash on the mouldings!
Now begins a convoluted painting process! I'll be spraying the stripes and tactical markings (Sky tail band, leading edge stripes) in sequence, before the camouflage. It's a system that works for me, though since I use enamel paints it's not exactly quick! I'll post some updates as I go along.
Note to self, don't forget the yellow propeller tips.
I've rubbed down the primer (applied last night) and have now moved on to "stage one".
Apply white to an area slightly larger than that to be occupied by the distinctive markings for Overlord. a.k.a. Invasion Stripes.
I always do the white first. Everything will cover this easily, including the black, camouflage colours and other tactical markings in yellow and Sky. White won't cover these, particularly the black and I don't want thick layers of paint on the model. The white coat you see above is the minimum to cover the primer. It isn't as perfectly evenly covered as the photo suggests which is fine. The guys applying the white on the original would have had the same problem!
Once this is dry I will mask off the white stripes precisely and spray the black ones.
Stage two is to mask the white stripes. A pair of dividers set to a scale 18" (14.3mm is close enough), patience and plenty of Tamiya tape required. This is followed by spraying the black stripes.
After that I sprayed the yellow on the leading edge of the wing outboard of the stripes. I checked a photo of my subject and the invasion stripes were applied over the inboard end of this marking.
Finally I sprayed the Sky tail band, resulting in this.
After an hour or so I removed all the masking. Why did you do that I hear someone at the back ask? I will have to re-mask the stripes and other markings before applying the camouflage but firstly I want to expose all the paint to the air for at least 24 hours to let it dry off and cure a bit. The white was masked after only 12 hours. I will also touch up the stripes at this stage, rather than at the end of painting, an added bonus.
Here's the current look.
Whilst this dries and cures a bit I will start on the dangly bits. I've got gear doors and undercarriage bits to spray with Alclad and a slightly dodgy looking spinner/propeller assembly to beat into shape.
Coming along superbly. Did you know that late V-1'S sometimes had a wing tip pressure detonator fitted for such tipping manoeuvres, this was to discourage pilots from doing this type of thing + it would destroy the V-1, aircraft and pilot.
