1/48 Sea Gladiator
  • geegad
    • Mar 2010
    • 2329
    #46
    nice detailing dave look forward to seeing more
    • Dave W
      • Jan 2011
      • 4713
      #47
      Tonight I've attached the rigging to the top wing.Then I drilled holes through the fuselage and lower wing.Next I glued the top wing to the struts on the lower wing.Then I threaded some of the rigging wires through the holes in the lower wing.Going to leave it to set overnight before I attach the cabane struts.When they are in place I will tighten and secure the rigging wires.I m not sure if the wires are too thick.The Gladiator had raf wires which were an oval section and quite thick.Anyone think they are too thick?.
      T
        Looks ok to me Dave but I have never done anything like that so am probably not best placed to say
          Not sure of the technicalities but it looks OK to me ..... Albeit a little confusing with all the wires everywhere
          I had a go at a 1/72 triplane and it drove me scatty ...... You must be on the serious happy pills with this one Dave.
          • Dave W
            • Jan 2011
            • 4713
            #50
            Originally posted by \
            Not sure of the technicalities but it looks OK to me ..... Albeit a little confusing with all the wires everywhere I had a go at a 1/72 triplane and it drove me scatty ...... You must be on the serious happy pills with this one Dave.
            The rigging has been driving me mad this evening.Went through 3 different superglues before I found one that would actually stick the fishing line to the wings.Then two of the cabane struts broke when I tried to glue them in place.So I've put the model away now and will have another go tomorrow.
              Stick the end to be glued in you mouth just before you stick it to the wing Dave, the moisture will aid the reaction.
              • flyjoe180
                • Jan 2012
                • 12418
                • Joe
                • Earth
                #52
                The rigging might be driving you mad Dave but it is valuable to see it being done step by step.
                • Dave W
                  • Jan 2011
                  • 4713
                  #53
                  It would have been easier with thinner fishing line.But I'm trying to get an approximation to the real thing.
                    This wires looks very fine to me Dave...not thick!
                    Looking a very nice work so far.
                    • colin m
                      • 8759
                      • Colin
                      • Stafford, UK
                      #55
                      Just don't do it the other way around.............................try explainging that to the A & E nurse...........................
                      • Dave W
                        • Jan 2011
                        • 4713
                        #56
                        Tonight I used some brass rod to replace the broken cabane struts.I then carried on with the rigging. Tried tensioning the slack wires with a lit cocktail stick.This worked quite well and for once I didn't mess it up.However,It wouldn't be me if I didn't make at least one cock up.Just noticed a hard lump of dried super glue on the top surface of the lower wing.Going to take some careful and patient sanding to get rid of it.
                        M
                        • flyjoe180
                          • Jan 2012
                          • 12418
                          • Joe
                          • Earth
                          #57
                          That is coming along nicely Dave. Hop eyou can recover that super glue incident up without too much damage to the paint work.
                            Looking good Dave.
                            • Dave W
                              • Jan 2011
                              • 4713
                              #59
                              I've almost finished the rigging now.Just need to add the tail plane wires.Should be easy after the trouble Ive had doing the wings.Ive also added the rudder control wires from some thin steel wire.
                                Wow, all dropped into order there Dave, looks really good.
