One problem that has been causing my some concern is the way the top fabric is fixed to the longerons; they appear to use some sort of dome head fixing which shows through the side fabric. The only way I could think of was the “drop of glue” method after all the covering has been applied, but as I said earlier I’m not keen. Why they don’t use flat heads and make life easier for us modellers I’ve no idea!
Whilst searching the shops for something suitable as a basis for making the trim wheel, I came across some very small beads, about ½ mm diameter, which should do the trick if glued to the longerons before the covering is ironed on. These were sold in a haberdashery shop and are for decorating home made birthday cards I think. I must admit that I get some peculiar looks as I rummage through the boxes in these shops, the other customers are invariably women; the things we do in the name of aeromodelling!
Back to the trim wheel, I couldn’t find anything so had to resort to building from scratch; I printed some templates on self-adhesive labels and cut out 3 blanks from 1/32 ply.
These were assembled, the rim marked at 18º intervals and half circles routed out. It didn’t work out as accurately as I’d like but a bit of filling using epoxy and micro balloons made all the difference. After 4 coats of sanding sealer it’s ready for painting.
A coat of silver Solalac, with a few extras the end result is good enough, especially as it will be mounted low down on the fuselage side so only the top section, as shown below, will be clearly visible.
