As Barry pointed out the stain has really brought out the grain; unfortunately, hoping not to sound too much like British Rail, it’s the wrong type of grain!
For such a high stress part of the aircraft the wood had to be close, straight grained. The way to simulate this is first to give the whole unit a dusting of matt white.
Then "stroke" the painted wood with 120 wet & dry in the direction of the "grain" that you want. Although not very clear from the photo, if you do ever try this technique you’ll find that it’s fairly obvious when you’ve done the right amount of "stroking" to produce the desired effect.
Then apply the stain, again in the direction of the "grain". This is only the first coat but I think it shows that the "grain" is now close and straight.
