Weighing up the pros and cons of my 2 ideas of how to do the cowl proved more problematic than I thought; I kept changing my mind as to the best method, I’m a man of instant indecision!
In the end I’ve decided to go for “Plan C”; the top and sides as separate units all removable, but just how to execute “Plan C” I’m not yet sure, it’ll make the construction more complicated but will have all of the pros and none of the cons of my original ideas.
The top section of the cowl is ready for its litho plate skin but I’ll wait until the lower sections are completed and I know everything fits OK before I do that, a 2mm bolt at the front, which will be disguised by the radiator filler cap, and a peg at the rear hold it securely in position.
From underneath you can see the method of attachment and the carbon fibre used as reinforcement. The “legs” that held it in position whilst the balsa skin was added have now been cut off.
