At last I’ve made a start on the bomb rack, or to be accurate on the bombs; there’s no point making a bomb rack if I can’t make the bombs! Here’s a photo to show what I’m aiming for. (sorry, I just couldn’t stop myself!!)
I decided that the only practical method is to turn the bombs, but therein lays the first problem; I’ve not got a lathe. If you work for Health and Safety I suggest you don’t read the next bit. I "converted" my vertical drill stand into a make shift lathe, very Heath Robinson but it works.
I started with a length of curtain pole and I’ve now got the basis for one bomb, but I don’t think I would be able to produce all 4 bombs and end up with them all being the same; they’re quite a complex shape.
I’m thinking of using this one as a master for a mould and then making a set of bombs from casting resin. I’ve never used casting resin before so any tips / advice will be gratefully received.
One question that immediately springs to mind is “is it tuff enough to withstand being dropped from the model?” They will be released quite low, I’d think about 50ft and at relatively slow speed over grass. For safety I intend to mould the front black bit from rubber and the arming vanes will be removed.
Hey Grahame! That looks just like my lathe! I cut out a pattern using the picture above and set it against each bomb as I turned them. They're not "factory perfect" but you can get them close enough. I drop mine from about 10' over pavement with only minor scuffing of the paint. Black rubber would fix that.
There was no chance of getting any casting resin until after the Christmas holidays and as Steve successfully turned his 4 bombs I thought I might as well give it go.
I’d turned the first one using a card template and found it quite a difficult and slow job; then I had a “eureka” moment, it does happen! I measured the diameters at various points along the length of the bomb, turned the wood as a series of cylinders and then simply tapered from one diameter to the next.
This produced the other 3 bombs very easily and quickly; just as Steve said, “ they’re not factory perfect” but certainly near enough for me and a lot cheaper than buying casting resin etc.
Making the bombs as a series of cylinders was simple and quick, which is just as well because I’ve had the make a completely new set of bombs. It wasn’t until I came to fit the rear fins that I realised that the rear section of the bombs was about ¼" too short. It just goes to once again emphasise the old adage “measure twice cut once”!
So what went wrong?
I first tried to turn the bomb using a single template of the wood to be removed, this meant that before the template for the widest part of the bomb got close to the surface the deepest cuts had to be made and this made the work piece quite weak and impossible to work with safely. I decided to “split” the bomb into 3 sections; I made templates for the front and middle sections, the rear section is just a straight taper so didn’t need a template. To ensure that the curves “flowed” nicely I decided to make the templates overlap by a ¼" but somewhere I got the measurements wrong! Having turned the front and middle sections I simply measured the overall length of the bomb and tapered the rear section accordingly not realising that the front of the bomb was in fact ¼" too long. When I decided to turn the other 3 bombs I used the master, not the photo, to set the callipers and measure the distances so duplicating the error. When I discovered the error I remounted a bomb in the lathe and tried to correct it but that didn’t work at all so 4 new bombs it had to be. It’s not all doom and gloom though; at least I now have some “spare” bombs to practice on.
I found that cutting 2 slots as a cross to fit the fins made the rear section very fragile and I was afraid that I might break the “legs”, so I cut one slot first, glued in opposing fins made from a single piece of 1/64th ply, then cut the other slot and fitted the other 2 fins once again as a single piece.
The bombs have been filled and sanded but I’m not too concerned about a perfect finish, after all if everything goes to plan they will be dropped from a great height and are certain to sustain damage or even get lost in the grass!
I turned a plug for the nose of the bombs from which I hope to make a mould to produce them in rubber.
The decision to add the bombs was only taken recently after seeing the photo of Steve’s model; I’ve done very little research on the subject myself. I’m using information supplied by Steve; if it’s good enough for him then it’s good enough for me!
I’ve no idea what the loop at the back is for but I do have some general information:
The SE5a was developed well after the time of dropping hand grenades or bombs by hand from the cockpit or shooting at the enemy with a pistol. The load it could carry was limited so 4 bombs of 20lbs each was the maximum, either as 2 sets of 2 bombs, one under each wing or a rack of 4 under the fuselage just aft of the undercarriage legs. The bomb release, operated by the pilot, is the out of focus black lever mounted low down on the cockpit side.
Pulling it back released a bomb, pushing it forwards reset the ratchet system, pulling it back again released the next bomb and so on until all 4 bombs had been dropped.
The bombs look really great! How did you do the little "lugs" around the nose piece?
I think the loop on the tail was to hang the bombs on a rack used on bombers. I have pictures with and without. The drawings I have of the rack show the bombs with loops, but they're not attached to anything.
Now you're into a whole new area of flying Grahame, trying to drop a bomb onto a target. That should keep you busy for a few hours and probably cost you a couple of bombs.
Maybe do it in short grass first!!
Lovely modelling job as always though. When is your anticipated maiden flight? I can't wait to see this model in the air.
I don’t know about bombing a target, I’ll be happy if the bombs stay attached until I “flick the switch” and then they actually release from the model!
It makes sense that they would produce standard bombs; in the photo of them mounted in the “vertical” bomb rack you can see that they have the mounting brackets that are used on the SE5a bomb rack but they do nothing in this one.
When I turned the nose section I included the “collar” around the end, having removed it from the rest of the wood I mounted it onto a cocktail stick and made a series of slots in the collar using the Dremmel with a thin cut off disc. I cut a strip of 1/64th ply about 1/8" wide by 3" long, put it in one of the slots protruding the correct amount onto the nose section and gave it a drop of cyano, I then trimmed off the excess length and repeated the procedure. When all the lugs were in place I gave the whole lot a good “cyanoing” then sanded the lugs down to the diameter of the collar.
It sounds more complicated than it was to actually do; it had to be easy because I wasn’t going to go to too much trouble as I have serious doubts that I’ll be able to produce rubber nose sections with such fine detail.
This is a compilation of posts “lost” because of the hacker attack
I intended to make a mould for the nose section from Plaster of Paris but a trip to our local chemists drew a blank; they even tried to order some from their supplier with no luck. During a recent decorating episode, which involved a fair amount of repair work to the walls in preparation for emulsion painting, we used Polyfiller, it seemed very similar to Plaster of Paris so thought I’d try it.
The plug was prepared by dripping molten candle wax all over it, heating it up with a hot air gun re-melts the wax and most of it drips off leaving a very thin layer. I mounted it on a plastic base with a wall of Plasticine and then gave the lot a spray with WD40.
The Polyfiller was mixed quite thin and carefully poured in to fill the mould. It’s not as quick setting as Plaster of Paris; it took about 2 hours to harden and be ready to remove the Plasticine and the base, then another couple more to dry before carefully easing out the plug.
It has actually turned out surprisingly well; there are a few places where the Polyfiller has broken away in between the lugs but to be honest I expected a lot worse. It remains to be seen whether or not I can use the mould to produce acceptable rubber nose sections; I still have my doubts.
There was a reply from Alan2525 about the type of rubber
Alan
I have not idea what sort of rubber I’ve used; I bought it years ago from the model shop, I think its intended use was for making moulds for casting Plaster of Paris figurines. It’s very soft with a “natural” colour; you melt it over a low heat then pour it either into a mould or over a plug dependant upon whether you’re making a male or female item, and then just let it cool and set.
Grahame
Being thermo-plastic it was easy to “touch up” the mouldings using a precision screwdriver heated over a candle flame. They’ve been glued to a 1/64th ply base with cyano and given a coat of black paint.
The finished parts are not perfect but I’m not going to too much trouble as they are “throw away” parts and as such will be attached to the bombs with double-sided tape for easy replacement, I’m sure they will need replacing after just a few “bombing runs”. I might make a set of better finished parts for static display.
The bomb release mechanism on the SE5a is very complex, no surprise there then! Although of course it is a proven design there is no way I could duplicate it in miniature so I’ve had to design from scratch
Steve used 4 different length pins to hold the bombs, being a control line model he was able to use a 5-way switch to control the release mechanism but I only have either the retract channel or, if I invest in a new 8 channel receiver, a proportional channel. A proportional channel would be the easiest to work with but I don’t like the idea, if I turned the knob a bit too far a bomb might almost but not completely release then with vibration it could release itself at an unplanned time, which could be dangerous, or at the very least loose me a bomb.
I will use Steve’s idea of different length pins and having decided that the “bang / bang” retract channel it will be, I need some way of “stepping” the release mechanism. I got my thinking cap on and came up with an idea inspired by the timing gear in a clock. I made a mock-up to see if it would work in practice.
The main release bar has 5 indexing pins spaced at 5mm intervals and will eventually have 4 bomb release pins each 5mm longer than the previous.
The release cam has a slot cut out from the centre; before an indexing pin is released from one end plate by passing through the slot the other end plate is in a position to "catch" the next indexing pin.
This is a series of photos showing the sequence as the servo moves the release cam arm backwards and forwards from one extreme to the other; the release bar steps by 5mm with each operation.
At the moment I’m using an elastic band, the spring tension will need to be worked out when it is actually releasing bombs, I hope!
